โMar-19-2016 08:13 AM
โMar-21-2016 06:51 PM
โMar-21-2016 06:41 PM
hohenwald48 wrote:
Flipping the axles (if it can be done) would get a good bit of additional ground clearance and allow for raising the ball mount on the draw bar. I'm not familiar with the axle configuration on that particular trailer.
If you can get things set up to provide for a higher ball mount you can have to bottom of the drop shank cut off if needed.
โMar-21-2016 05:53 PM
โMar-21-2016 05:47 PM
โMar-21-2016 04:12 PM
โMar-21-2016 03:46 PM
My TT is actually a 2010. I was able to be in touch with the previous owner when I got it and he had the bearings done last year.
โMar-21-2016 03:39 PM
hohenwald48 wrote:
lukenick wrote:
None of you see a problem with the spring bars being so low to the ground? I scrape so much with them like that.
Yeah, we see it. The reason the spring bars are low is because the ball mount is low. The ball mount is low because coupler is low. The coupler is low because the manufacturer installed an underslung coupler. Your spring bars appear to not be parallel with the trailer frame either but that's a minor adjustment and easily fixed by removing a washer from the ball mount tilt adjustment.
We're assuming that in the picture (page 2) where you show the whole truck and trailer (but we can't see the hitch) that the trailer is sitting on the hitch and not the tongue jack. If that's not true then ignore everything I've said in this thread.
โMar-21-2016 03:36 PM
โMar-21-2016 02:38 PM
โMar-21-2016 01:53 PM
โMar-21-2016 01:29 PM
It looks to me that the drop on the ball coming off your truck is too much. You could raise the ball higher on that hitch (to the top holes), and save 3-5"
They had to add that drop because anything higher and the trailer would not be level due to the underslung coupler. It is an 11" drop and the head is mounted to the very bottom holes.
โMar-21-2016 12:25 PM
โMar-21-2016 12:04 PM
โMar-21-2016 10:32 AM
hohenwald48 wrote:
Yeah, you really need a power tongue jack. Easily worth a few hundred extra bucks. I can't imagine life without one.
โMar-21-2016 07:33 AM
