Jan-07-2015 07:10 PM
Jul-03-2015 04:29 AM
SoundGuy wrote:
An old thread but since it's been revived I'll mention my own solution which was to add 25' of potable water hose to the pump output, resulting in the pump operating so quietly I also added a light so I'd know when it was running.
Silencing the Water Pump - 3 Pics, 1 Video Demonstration
I replaced the hose 3/4" GH connectors with 1/2" FPT but I notice ShurFlo now sells 3/4" GH > 1/2" FTP Wingnut Adapters that would allow using a standard potable water hose for this purpose without having to first replace the connectors with 1/2" FTP.
Jul-02-2015 06:03 AM
fallsrider wrote:
I know this is resurrecting an old thread, but I made my own pump silencing kit yesterday and installed it, along with an accumulator tank. I had already mounted the pump on a thick sponge. By adding in braided water line after the pump, the noise dropped substantially. My pump already had braided line from the tank to the pump.
Jul-02-2015 03:38 AM
Jan-11-2015 10:24 AM
Jan-10-2015 05:22 PM
LarryJM wrote:Jetstreamer wrote:
I have my pump on a rubber "mouse" pad in addition to some braided washing machine hoses which are formed in a loop. Pump runs quiet. It is true like some have said that it is acceptable to have some "quiet" pump noise just to make sure it's working correctly.
I am a big proponent of a pressure tank. Why not have the pump cycle less and be able to run a gallon or two out of the faucet without having the pump going. I have a two gallon model (fits in an egg crate) and I don't think one would need anything bigger unless you had a whole bunch of extra space.
Be careful with the type of pump you run with a pressure tank. Some models have a bypass system on them that reduces flow just before the pump shuts off to ease any pressure bumps. I have found these very hard to adjust to work with my tank.
I run mine at close to 50 psi with no issues.
There aren't any winterizing issues nor will a pressure tank setup necessarily use anymore antifreeze than without a tank. When filling antifreeze you just run the pump, let the tank fill slightly, shut off the pump and then distribute the pink stuff through out the system. When it comes time to drain any liquid out of the pressure tank all that needs to be done is to turn on a tap with the pump off and the air precharge in tank will drain it out.
There is a lot in your post I question...
1. I don't see how with a 2 gal tank you will be able to run a gal or two thru a faucet w/o the pump coming on. You might be able to get like 8 or at most 16oz out of a faucet w/o the pump coming on, but not much more than that.
2. It seems obvious to me that it will take at least as much more antifreeze with a tank that is equal to the tanks volume over a non tank system. You have to fill up that tank if it's located close to the pump before any liquid will get to the lines, etc. Also, since the tank is going to be lower than most of the plumbing/faucets you will always have some water head pressure back on the tank that you have to overcome to get liquid out of the tank so any tank precharge pressure is not going to really help much.
Larry
Jan-10-2015 04:54 AM
Jan-10-2015 03:42 AM
Jan-09-2015 05:19 PM
Jan-09-2015 11:54 AM
Jan-08-2015 06:20 PM
Jan-08-2015 06:07 PM
Jan-08-2015 06:50 AM
Jan-08-2015 06:15 AM
Jan-08-2015 06:14 AM
