Apr-08-2019 11:25 AM
Aug-27-2019 11:26 AM
gmckenzie wrote:ZINGERLITE wrote:
I went and bought plastic valves from the plumbing section at lowes and screwed them onto the 3/4" fittings where the caps go. No more need for caps. Just turn the valves.
I did the same with mine as well as the fresh water tank drain. Much easier to deal with.
Aug-27-2019 05:20 AM
bob213 wrote:
Try amazon: ASIN: B00IRUKIO8 or do as suggested and buy pex valves and be done with it.
I bought these from Zoro tools.com
Or these from Amazon
valve
Aug-27-2019 04:23 AM
Apr-12-2019 10:26 AM
racer4 wrote:
Is this the right size and type of valve?
1/2" PEX x FNPT Polymer Ball Valve Inline
I want to order valves to replace the caps on my low point drain lines.
Apr-09-2019 06:58 PM
Apr-09-2019 05:13 PM
Apr-09-2019 04:38 PM
Lemonhead78 wrote:
So what am I suppose to do. I checked hardware stores and the rv parts department where I bought trailer it and no one can help. I’m getting depressed over this. I called forest river and that was a joke.
Apr-09-2019 02:57 PM
Apr-09-2019 12:51 PM
Lemonhead78 wrote:mobeewan wrote:
If the cap is a Flair-it cap and looks like the one in the link, there is no gasket. Those caps are used to cap Flair-it fitting where the PEX tubing has been removed. They seat against the Barb the PEX normally slips over before tightening the nut used to hold the PEX to the fitting. They will hold pressure up to the rating of the fitting, valve or PEX tubing without a gasket.
I have a couple I keep on hand in case I have a plumbing problem and have to disconnect a piece of PEX until I would have time to make a repair. I used one once to temporarily cap a tee I added where I was adding a new PEX line where I was installing a captive air tank. I still needed to use the trailers fresh water system before I had time to finish the tank install.
Apr-09-2019 10:02 AM
Apr-09-2019 05:30 AM
valve
Apr-08-2019 06:33 PM
Apr-08-2019 06:09 PM
Apr-08-2019 03:38 PM
Lantley wrote:
THe lines that were not cap are likely the vent and drain line for your fresh water tank. THey do not need any caps!
