main seal is degrading.
Limoges_Camper
Has anyone ever had to replace the main seal for the tip-out tent? Mine is showing signs of degrading and I'm wondering what kind of a job it is to install a new one (and how expensive these seals are).
This is the seal I'm talking about (picture is rotated) :
Just learning all about trailering with something longer than my 17 1/2' boat or pop-up tent trailer.
I accept any and all advice you can give me, and I hope to be able to help in my limited capacity. ๐Ÿ™‚
11 REPLIES 11
ShawnMG
I used a combination of alcohol and i think it was goof-off. What ever removes the old stickiness and dirt.
Me, DW, 2DS (10, 9)
2011 Chevy Silverado Ext.
2015 Rockwood Roo 233S
Limoges_Camper
ShawnMG wrote:
Just did mine over the summer. Actually did twice. First one had a hard time finding the right size in white. Was a little too small. Also make sure it is a good quality manufacture like uni-lock. First one the double sided tape stuck better to the trailer than the D-seal. Seal came off of the trailer. Didn't take long to replace.
Thank you! What do they recommend using as a cleaner? I like mineral spirits myself, but some manufacturers prefer an alcohol.
ShawnMG
Me, DW, 2DS (10, 9)
LEMII
Just replaced the D seal on my rear bunk opening. Hardest part was removing the old adhesive. I used a narow chisel, and small putty knife, and some acetone and rags to remove it. Took about 45 minutes to get a good clean surface for the new seal. Be careful when scraping close to that tent material, you don;t want to slip and end up with a not-so-nice tear!
Me
My lovely and gracious wife
Maggie, our Yellow Lab
2007 Jayco Jayfeather EXP 23B
2008 Toyota 4Runner V8 Limited AWD
xplodn
As far as maintenance and mods go this is small time. Should be very straight forward for you to do.
Limoges_Camper
Having done some research, I now know this is 3/4" ร— 3/4" smooth face D-seal with adhesive.
It will be fun doing this job....
xplodn
Hmmmm, thats really just stuck on? Mines fairly well flat and starting to show some age (2003 Kodiak) and I thought about replacing it. I need to do that and have the front track that secures to the trailer sew on (guy I bought it from had rear done and gave me one for the front).
It also feels like the bunk fabric could have been mad an inch longer as its very tight over the velcro
gwh1bass
This is t5he seal I'm talking about (picture is rotated) :
That looks exactly like the seals on my 2006 model year, in fact your tent end looks the same, I have a KZ Coyote.
I have emails the folks at Uni-Grip and it appears like they have a similar replacement, though it appears it may not be available in white, but I think black would create an OK looking accent.
Seems to me that the old needs to be pealed off, probably clean up the old glue residue and install new sticky backed seal.
My bunk ends are curved at the top (end) and that would be the only potentially tricky part to install.
Currently working on redoing the caulking on all the vertical seams, which have also deteriorated.
Jerry9n
If you can't get it locally, seals are available online.
Click here for a catalog of about any kind of seal.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Primus IQ
HTT Mods
Limoges_Camper
ScottG wrote:
Unless I'm looking at the wrong thing it just looks a little dirty or mildewed to me. Not really any degradation IMO.
The image is rotated, so if you look at the bottom right, you can see where it's cracking and bits have fallen off.
I just found out it's a 3/4" D-seal with adhesive, and my local place will sell it to me for about 2 bucks a foot.
ScottG
