Aug-20-2013 06:06 PM
Aug-21-2013 04:53 PM
Nvr2loud wrote:Old-Biscuit wrote:
Are you undoing the arm locks (rafter knob) before trying to raise them?
I use a silicone spray occasionally.....not because they are difficult but because I don't like the chatter when sliding the rafter up/down channel
Mine are easy to raise and I'm actually doing it wrong...
1) I pull the awning away from the trailer (unrolling)
2) Extend the rafter arms and put a little outward pressure on each for some tension
3) Tightly lock the rafter knobs
4) Extend the main arms to desired height.
I'm too short to reach the rafter knobs when the main arms are fully extended, so I do them up earlier. I have had no binding problems at all. I'm thinking something must be bent or jammed elsewhere in the OP's awning system
Aug-21-2013 11:09 AM
Aug-21-2013 10:29 AM
That is not the wrong way. Your procedure is the correct way! 🙂
Barney
Aug-21-2013 08:33 AM
Aug-21-2013 07:13 AM
Aug-21-2013 07:08 AM
Aug-21-2013 06:56 AM
Aug-21-2013 06:38 AM
Aug-21-2013 01:46 AM
Aug-20-2013 09:47 PM
Aug-20-2013 09:13 PM
Aug-20-2013 07:46 PM
Aug-20-2013 07:28 PM
Aug-20-2013 06:25 PM
