Microwave buttons
2012Coleman
We have never used the microwave as much, but I noticed that almost none of the buttons work. I can get it to start, by pushing the add 30 second button, but thats about it. Its a typical RV microwave. Anyone ever had this issue? I guess it can be replaced easily.
Click For Full-Size Image.
2018 RAM 3500 Big Horn CTD
35 REPLIES 35
Bumpyroad
Doug33 wrote:
I am relatively on top of technology but some microwaves confound me. I can only get the one at work to cook by pressing the 1 button and it goes on for 1 minute. If I need less than that, I need to stop prior. We've rarely used the microwave in the TT, but it seems like it works okay.
I'll bet that if you press "2" it will run for 2 minutes. ๐Ÿ™‚
and that must be the only microwave in the world that doesn't have a 30 sec. or so add time button.
bumpy
Doug33
2014 Keystone Bullet 281BHS
2002 Chevy Avalanche 5.3L 4x4
Equalizer hitch
Nights spent camping in 2015: 25
Next trip: mid-April 2016?
Rubber_Ducky1
2012Coleman, similar to what Bumpyroad said, open a cabinet door beside the microwave. I'll bet you'll see the microwave power cord coming through a hole in the side of the cabinet and going to an outlet.
Bumpyroad
2012Coleman wrote:
Thanks for all the suggestions - will try this afternoon. I actually am a read the directions person, but somehow the MW manual is mising from my packet. I guess I'd have to unscrew it from the cabinet to unplug it.
before unscrewing it, unplug it, just turn it off, set the time, and try from there. are you positive that the cord doesn't go out thru a hole to another plug in location?
bumpy
2012Coleman
Bumpyroad
mine isn't plugged in right now so can only guess, but did you set the clock (to any time). my coffee maker requires that, don't remember about the MW. when it is showing the time, push button #1 only and it should start/run for 1 minute. if it doesn't it is defective.
bumpy
Rubber_Ducky1
2012Coleman, My friend and I both have the same High Pointe microwave in our campers that you have. Both of our microwaves are acting just like yours. Our campers are on seasonal sites. September 15 before I left our site I unplugged the microwave from its outlet. Friday, September 19 I plugged the microwave back in. It worked like it should ALL weekend! My friend and my trailers are 2014 units bought in summer of 2013. I believe the symptoms your, my friend and my microwave are having is a manufacture defect. I am having a hard time convincing the owner of the dealership where I bought my trailer that it is a manufacture's defect.
doxiluvr
It will keep beeping until you either take the food out or at least open and then shut the door.
And if you use the express cooking buttons (usually 1 through 6) you can stop it whenever you want just by hitting stop or opening the door. Then hit start again if you need more time.
My microwave in the TT is only about 900 watts and the one in the house is 1100; so sometime you have to adjust the cooking times depending on the wattage of the microwave. Longer if its a low wattage and maybe a little less if it is a high wattage. Just need to get used to it. And read the book that comes with it.
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 ChiWeenie - Abby
4 grown kids, 6 grandkids, 2 great-grandchildren
1 2007 Yamaha v-Star 1300
opnspaces
Navigator II
Navigator II
Open the door? Just a guess.
12rvjoe
Not to hijack but anyone know how to turn off that darn BEEPING when times up ..
Bumpyroad
Just went out and looked at mine. it is exactly the same and it does have Express cook for 1,2,3,4,5,6 minutes. you should be able to just push one of those numbers and it will run for the labeled amount of time at high power. you all can fire up an empty one but I won't on mine.
bumpy
myredracer
We have the same MW. They work differently than the typical household type. You need to press the time button first, then enter the time, then the start button. Nothing will happen if you don't and it will seem as if it is broken. I think the other functions are the same deal, but I'd have to go out and look at ours.
In a household type, all you do is enter the time first, then hit the start button. Not sure why they don't make RV ones the same.
I found I had to stop and consciously remember what to do first before I tried to get it to run. A couple of seasons later with this MW, I'm finally getting it right the first time, lol...
If still having difficulty, not that anyone should have to (I haven't), but you *could* always read the manual. Then, if even that doesn't help, there must be something faulty.
dave54
ScottG wrote:
FireRob wrote:
Bumpyroad wrote:
hopefully you have a cup of water in it before trying to start it.
bumpy
Why?
You should never run a micro empty.
Used to be true. The newer models no longer have that problem.
So many campsites, so little time...
ScottG
FireRob wrote:
bumpy
Why?
xteacher
We have this microwave in our camper. Try pushing Timed Cook first, followed by the amount of time you want it to cook, then Start. This will cook the food on high.
If you want a power setting less than high, push Timed Cook first, followed by the amount of time you want. Then push Power, followed by the power number you want, then Start.
Hope this helps. I will say that this microwave is much weaker than the one we have at home, so you'll have to experiment with the settings to get something to cook the way you're used to.
Beth and Joe
Camping Buddies: Maddie (maltese/westie?), Kramer (chi/terrier?), and Lido (yellow lab)
2017 Keystone Bullet 248RKS
2014 Aliner Expedition Off Road
2013 Ram 1500 HEMI
