Oct-02-2013 10:36 AM
Oct-03-2013 07:59 AM
Oct-02-2013 08:26 PM
ktmrfs wrote:Marshall went bankrupt a few years ago so those changeover regulators are no longer available. :M My Marshall stopped working correctly so I put in a Camco. Now I need to do the same mod since the window on the Camco sits where you can't see it.
I just have the marshal flashing yellow changeover indicator in my trailer that couples to the marshal auto channgeover valve. ....
Reese Dual Cam Straight Line HP Sway Control
Oct-02-2013 08:24 PM
Lantley wrote:
Leaving one tank off is foolproof in that you will always have a full tank and never run totally out of gas.
Oct-02-2013 08:09 PM
ktmrfs wrote:MTTitan wrote:Lantley wrote:
When I had two tanks. I always kept one off and did not bother with the auto switch function. Yes you run the chance of running out over night, but why bother with all the checking? If it were very cold and I thought I was near the end of the 1st tank, I may turn on the second tank. Otherwise I did not worry about it.
The appliances would let me know when the tank was empty.
The auto change over is a joke. What's auto about it? It automatically forces you to monitor your tank capacity. Otherwise if you don't monitor your tank the auto change over will automatically let you run out of propane.
Manually switching the tanks is easier than having to monitor capacity and deal with auto changeover valve.
X2
the marshall changeover LED indicator lets you "have your cake and eat it to". LED flashes in the trailer when it changes over, no need to get out and look, and you won't run out of propane, the LED flashes as soon as it changes over to let you know your on the second tank.
before installing it, yes, I kept the second tank off, to know when it changed. No more, and no more waking up to a cold trailer or fridge going off and not knowing it.
Oct-02-2013 08:00 PM
Oct-02-2013 07:54 PM
X2
Oct-02-2013 07:37 PM
Oct-02-2013 01:36 PM
Oct-02-2013 01:18 PM
Oct-02-2013 01:07 PM
Oct-02-2013 01:01 PM
Oct-02-2013 11:49 AM
Oct-02-2013 11:38 AM
Oct-02-2013 11:34 AM
