โSep-08-2017 07:10 AM
โSep-10-2017 08:24 AM
โSep-10-2017 01:11 AM
โSep-09-2017 07:39 PM
โSep-09-2017 04:47 PM
billy1davis wrote:
So what I understand now is that no matter how new the truck is if it has leaf springs it is going to have the same ride but if I put air suspension and get rid of the leaf springs it will ride0 as good or better then I brand new truck with leaf springs
However according to another person on this chain of holsteins a brand new truck outfitted the way it comes stock or ride better than my old truck
billy1davis wrote:
, so if I install kelderman or air link suspension on my 2001 Dodge Dually I can be assured of a great smooth ride that is good as a new truck I hope that if there is anybody that disagrees with this they'll let me know probably as I need to do something right away for my wife to be able to continue to ride in this truck
โSep-09-2017 04:05 PM
โSep-09-2017 04:04 PM
โSep-09-2017 03:50 PM
โSep-09-2017 10:09 AM
billy1davis wrote:
Which truck is the most comfortable when loaded with a heavy camper?
โSep-09-2017 09:24 AM
โSep-09-2017 07:55 AM
Bedlam wrote:
My Ram 5500 rides better with the Host Mammoth than Arctic Fox 811. Empty, it is very stiff but not what I would call jarring unless driving empty on bad roads.
โSep-09-2017 07:22 AM
billy1davis wrote:
So I met a camper whois hauling about the same load as me on a Ford 350 one ton swd 4wd and he has put 60k on it and it rides just fine is it possible Ford better.and his 4wd mine 2wd....more space for betteraction
.is
โSep-09-2017 07:12 AM
billy1davis wrote:
What air ride do you have and what is a 16 Ram
โSep-08-2017 11:40 PM
GpnAZ wrote:
1. You can't fit a sway bar on the trucks fitted with factory air. I contacted Helwig and they have no plans at this time to develop one. The sway is a bit better than our 2004 ram 3500 with the same camper, but it would be nice to further reduce it. I might design my own.
I have the Hellwig Big Wig sway bar on my 2017 Ram w/ factory air assist. I had a 2014 SRW 3500 Ram that I put a Torklift Super Truss on and the HellWig bolted right up to that. I took the Super Truss and HellWig sway bar from that truck and had it installed on my new 2017' Ram. My new Ram rides so much better empty or loaded then my 2014' Ram did after all the suspension mods I made to carry the AF811. I made no mods to the suspension of the 2017' Ram except for the sway bar, the factory air assist really works nice in my case.
โSep-08-2017 09:04 PM
work2much wrote:Kayteg1 wrote:
I like the idea about air suspension Dodge offers for rear and reviews are good so far.
We have been pleased so far although...
2. The stock rear shocks seem to be shot after 15,000 miles. Passenger side showing a leak. In all fairness these are all miles with our camper on and a couple thousand of those on dirt roads in Alaska. Not a big deal, I was going to replace them anyway.
3. There is no way (that I am aware of) to inflate the bags individually. This became apparent with our AF1150 which is heavier on the slide side. In the old truck I would just add more air on that side.
The air bags look a lot like standard aftermarket units. If I were to do it over I would have ordered the truck with the standard heavier rear springs that would allow stable loads, sway bar and aftermarket airbags (if needed)
