MOTOR OIL ?
Oasisbob
After learning a certain oil change facility does not always change the oil filter when doing an oil change I went back to doing it myself. Things have changed on the motor oil shelf. So many choices. Synthetic, petrolium, blended. My question is if I go synthetic and need to add oil later can I mix petrolium with synthetic? What is blended? Is "high mileage" oil any different? Howq? Thanks for any info you may share
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
69 REPLIES 69
valhalla360
Nomad III
Nomad III
opnspaces wrote:
I've never heard of this. Are you referring to a particular local shop, or is this a chain policy?
My guess is he bought the super cheap oil change that doesn't include lube & filters.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BenK
Most all engine oil are made from crude.
The difference is in how they are refined and additive packages
Early days of synthetic did have OEM’s not recommend mixing
Today, most say ok and I’d add of the same spec
Issue is with their additive package compatibility and not going to kill an engine instantly. Just altered additive package
As for cheating, sure thing...occasionally local news expose has a complaint and proved via marked oil filter and oil analysis
Do my own, but occasionally use a drive through when squeezed for time and one place just change their rules requiring to stay in the vehicle...so can’t see the oil drain n filter come out
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
opnspaces
Navigator II
Navigator II
MitchF150
I bring along a couple qts of the same oil I use along with me on long trips in case I need to top off for whatever reason..
So far, have not needed to, but it's nothing to take it along anyway..
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Oasisbob
Thanks guys. I knew you would know. This is what makes this forum great. People helping people. In my day mixing synthetic with pertolium was a no no. Things change
Oasis Bob
2018 Ford Explorer
HAPPY TRAILS:)
srt20
deltabravo wrote:
It's not recommend to mix oil types.
by who?
philh
mix and match, change up if you like. Today's it's an old wives tale, that actually had a basis of fact in the past.
Friend was a mechanic that had a car come in with a failed engine. A little thick sludge came out of the drain. After an investigation, turns out the female owner religiously took her car to the same quickie oil change place for an oil change every 3000 miles... except for (IRC) 50,000 miles, it never got changed.
FishOnOne
You can mix synthetic oil with conventional. (See Synthetic Blend oil below).
Blended oil is marketed as Synthetic Blend which is both synthetic and conventional base oils mixed together, but there's no requirement for how much synthetic is used.
High Mileage oils typically have more seal conditioning additives to help prolong the life of the seals. I prefer not to use these oils unless you stick with them for the life of the engine.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
deltabravo
Lwiddis
Why aren’t you following the vehicle manufacturer’s recommendations?
