Moved my trailer a foot or two because
VTR
The tires were sitting on bark where we add tomatoes growing once. I figured the bark was retaining a lot of moisture and it was not good for the tires. Now the tires are sitting on a rock gravel section of our drive. Am I correct that this was not the best place for the tires to sit during the winter months?
12 REPLIES 12
rbpru
I pulled mine unto a pair of 2x12s for the winter.
When the cold snap is done, I will check the tire pressure.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
colliehauler
You can google tire storage, this is from Goodyear. (( do not store tires where it is wet, oily or greasy)). They have a lot more storage tips as well.
If the tire sinks enough the standing moisture can rust the rim and brakes.
ScottG
mtofell1 wrote:
I'd worry more about them sitting for too long in the same position and developing flat spots than what material they were sitting on. The longest my TT has ever sat is about 3 months over the winter. Much longer and I was thinking of jacking it up and spinning the tires 180.
That was a problem with the old bias ply tires and even then, just driving a few miles would fix them up.
My TT sits for nearly 6 mos out of the year and the tires are fine in the spring.
I wouldn't bother turning them.
sail2liv
if worried just pull it onto level boards that you carry with you...keep ctp at or a few pounds above max
mtofell1
coolmom42
I don't think moisture is the issue. I think it's sinking into a softer surface, which makes it hard to get out, and makes a mess on the surface. Tires are made to be wet, makes no sense that moisture would be a problem.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
ScottG
I've always wonder why sitting on a moist surface would bother a tire. All my TT tires have sat in wet dirt or gravel and never rotted.
Around here even vehicles that move every day here are subjected to moisture everyday and they don't seem to suffer.
What aspect of this am I missing?
beemerphile1
My trailer tires sank about four or more inches into the gravel drive one winter. Since then, I have a six feet long 2x8 under the tires on each side. The 2x8 spreads the load.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Doug33
My TT sits on stone, but during rain, puddles form around the tires in the low spot. I've never had a moisture issue. Exposure to sun/extreme heat is a different story....
2014 Keystone Bullet 281BHS
2002 Chevy Avalanche 5.3L 4x4
Equalizer hitch
Nights spent camping in 2015: 25
Next trip: mid-April 2016?
coolbreeze01
I would park the tires on wood or concrete.
2014 Sandsport 26FBSL
Turtle_n_Peeps
My TV, truck, BMW, Acura, and several other vehicle tires sit in water or snow or whatever 24 hours a day. I have never had any problems with them.
UV is bad for them but water? No, they are fine in water.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
colliehauler
Correct.
