My belly is sagging...
Gsturner
The beer belly I understand. I'm talking about the underbelly on my Rockwood. Each of the underbelly panels seem to be sagging significantly at their center. Hadn't noticed this phenomenon until yesterday in Santa Rosa NM with ridiculous winds. The plastic panel at the rear behind the bumper completely ripped loose from the top edge. Appears glued/plastic riveted? Duct taped that back in place-Nothing solid to screw it back into-arrgh! Anyhow, the "protected underbelly" feature I specifically sought out is now compromised. Heading to Quartzsite with some cold weather yet to come. Sigh.
SKP 115048
2016 Winnebago View 24M
2015 Harley Heritage Softail as toad
Retired:
2007 Titan LE with the Big Tow Package
2010 Rockwood 8315BSS
2008 Suzuki GZ 250-Response to 3/4 Life Crisis :C
23 REPLIES 23
wmoses
Have another beer regardless. Sounds like the downward bulge is unavoidable due to stuff on the other side. Just patch the failure and enjoy the camping.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Desert_Captain
Gsturner wrote:
I got some good pics, both from the side and from the rear looking forward. Unfortunately I am down to an iPhone and Kindle Fire and can't figure out how to post them ๐Ÿ˜ž I did find a "service flap" cut in by the dealer to effect a repair on the entrance steps. I will apply duct tape to that as well. Looking from the rear, the sag is uniform. All panels seem to be bumped up against something solid (tank, plumbing, whatever) except the rearmost one. I thumped/pushed up on all of them with no water sloshing sound nor drainage, so I don't think leakage is an issue. Maybe I should ignore the perceived sag and have another beer.
Sounds like a good plan to me. If you can lay your hands on some Gorrilla tape you'll find that it out performs Duct tape by a mile. :B
Gsturner
SKP 115048
Retired:
wmoses
Since one of the panels flew of there could be a problem. On mine the underbelly is not flat and I suspect it is that way because of the way out covers the tanks and such underneath, as was mentioned above. Last time I looked mine seemed to have a small grating type opening on the centerline probably to allow drainage should there be a leak. That makes sense.
Regards,
Wayne
_
Gsturner
Desert Captain wrote:
Any chance you have a water leak? If water is leaking down into that area the weight will quickly produce that sort of sag as it seeks the lowest level. Got any pics? :h
I've not had the best luck posting pics on here, but I'll try. I'm in the KOA in Bernalillo for the weekend. I'll poke around under there a bit more.
SKP 115048
Retired:
Desert_Captain
Steeljag
Gs-
Can you see into the space? Anything that may have come loose and is forcing the belly down?
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
pappcam
My 2012 Flagstaff looks like it sags in places too but I just chalked it up to the tanks and the fact that it's just that corrugated plastic material that isn't that rigid to begin with.
2023 Grand Design Imagine 2970RL
2011 F150 XLT 5.0
ScottG
Are you sure it wasn't always that way? (the trailer that is) ๐Ÿ˜‰
Mine looks like it sags but it's because of the way it wraps around the tanks under there.
