Jul-17-2014 11:20 AM
Jul-31-2014 10:45 AM
Jul-31-2014 12:10 AM
jriggs10 wrote:
Whoo hoo! We got our camper, and it is awesome! I have a few questions:
-When I drive it (this is my first camper) it seems the overhead part shifts around a bit, I would have guessed it would be tight and not sway much at all.
What you see is normal; it is caused by the flexing of the truck's frame.
-The heater fan doesn't work, any ideas where to start getting that fixed?
A lot of the early TC and TT heaters don't have a heater fan.
-None of the plugs work when it is just run on the battery, is that normal?
The 120VAC outlets don't run on the battery
-Should I run the fridge on propane if I am not plugged in electrically?
Yes.
-Should I drain my water tank each time I use it, or will it last a while in there?
If you filled it with "city water" it should be OK for a couple of weeks.
Thanks in advance, your help has been invaluable so far!!
Jeff
Jul-30-2014 10:22 PM
Jul-20-2014 03:17 PM
Jul-18-2014 02:00 PM
Jul-18-2014 01:45 PM
Jul-18-2014 12:13 PM
jriggs10 wrote:Maybe you can sorta work backward and figure out which model you have. here's a link to NADA's page for 1998 Caribous- looks like model name/number is based on length. NADA doesn't give weights, but once you figure out which model you have you might try Googling that plus "weight?" and see what comes up.
I hear you, just wanted to make sure the camper weight wasn't way over my truck limit...
Jul-18-2014 12:01 PM
Jul-18-2014 10:18 AM
jriggs10 wrote:
Should I be concerned that the plate next to the door does not have any info stamped into it? I really don't even know what model number it is.
I know that Fleetwood went under a few years ago, but is there anywhere to get more info on the camper, like an owners manual, etc?
Jul-18-2014 07:08 AM
Jul-18-2014 02:54 AM
Jul-18-2014 02:01 AM
Jul-17-2014 10:12 PM
Jul-17-2014 01:27 PM
