Jun-12-2014 09:12 PM
Jun-14-2014 09:29 AM
sleepy wrote:
And, when it isn't working because you weren't level for a prolong period of time the "fix" is to turn it off for a couple of days, let the coils "rest" so the system equalizes... drive around, shake up the ammonia... then and only then with the fridge level restart it's heat source (110 VAC, 12 VSC, or propane flame)
Jun-14-2014 12:49 AM
Jun-13-2014 07:19 PM
RichieC wrote:
As others have implied, the freezer runs the whole fridge.
The freezer "leaks" cold air down into the fridge part.
Unless there is something blocking the air passages, and the freezer is working, then the fridge will eventually get cold.
Jun-13-2014 06:38 AM
Jun-13-2014 06:16 AM
Jun-13-2014 06:14 AM
Jun-13-2014 06:01 AM
Jun-13-2014 05:28 AM
CAJW wrote:
Really hate to have to carry a large ice chest for the cold stuff.
Jun-12-2014 11:51 PM
Jun-12-2014 09:49 PM
robsouth wrote:
A fridge can take as much as 24 hours to cool down. If you put anything in it that was not already cool, it can take longer. Mine takes at least 12 hours to reach temps and then I load with stuff that has already been refrigerated. Maybe you have just not waited long enough. Usually if the freezer is working well, the fridge will also as there is only one cooling unit for both.
Jun-12-2014 09:36 PM
