Got the 100K miles blues, F-150
mosseater
As some of you remember, I recently did the plug job on my F-150 and was very sucessful in it's outcome. After getting the coolant and fuel filter changed, and a new fuel pump control module installed, I found out today that the ticking I've been hearing for 60K + miles isn't cam phasers at all, but an exhaust leak. Service writer was surprised to hear this, but he wasn't there when I bought it 8 years ago. The story always changes when the warranty runs out.
So now, for upcoming inspection, I need to get that repaired (to the tune of $800!) and maybe THEN I can move on my way to the next 100K.
I'm just not going to get rich driving a vehicle, am I?
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
18 REPLIES 18
BenK
ib516 wrote:
Sometimes - that's best. I know for those of us that have the tools, knowledge, and ability to do the work ourselves - that decision isn't easy, but the stress just isn't worth it sometimes.
Am now older and lacking (some times...too many times) the 'ability'
and the 'want2' to do it myself
Sub just back from SMOG and new starter (reduction gear head). Not too
long ago, I'd have jumped down there to change the starter (2 main
bolts, one positive bolt and a control wire plug).
Bad back and bad neck had me hesitating...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
mosseater
I've been studying some vids on the repair and I've decided to let the garage do it. Too much to tackle without a garage and backup vehicle. Another week of rain like this week and I'm screwed. Just gonna bite the bullet this time.
Sunset Creek 298 BH
mosseater
I'm considering doing it myself. If it ever stops raining long enough I can get out there and take a look-see. I'm no stranger to removing broken studs. Even in tough places. Just not sure if I want that level of aggravation again after doing my plugs (although, it did turn out pretty well in the end). The leak is definately at the head surface. The mechanic at the Ford dealer pointed it out clearly.
It was explained to me you have to take a bunch of stuff out of the way to get at it, so I'm sure that's where the labor comes in. My other driver is a motorcycle and it's currently down too, so having an extra vehicle to drive is problematic currently. The more toys you have, the more stuff you have to fix. Simple equation.
Hope to get a look at it tomorrow and make a decide on it. Thanks for all the input guys.
Sunset Creek 298 BH
gmw_photos
lbrjet wrote:
I just had my right side done(covered under the ESP plan) at 61K miles. Took 1 1/2 days. They have to completely remove the shock and mount and other things just to get to the right side manifold. They broke bolts and had to re-tap new holes. The service writer explained that it is simply a very bad design on the right side of the 5.4L. Left side is much easier to get to.
It's making $800 at the shop sound like a pretty good deal !
lbrjet
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
BenK
Been through most of the listed problems on numerous headers in many of
my old vehicles and buddies vehicles...
First, you HAVE to have it done soon...as the very hot exhaust gases
running out of that leak WILL erode the metal. If the leak is on the
exhaust side...not so bad...but...if on the head side...might have to
remove the head and have it machined ('one' of worse cases)
You have enough miles on it to potentially have some of the studs or bolts
rusted and not come out.
If you break one, either easy out or remove the head for a trip to
the machine shop
Not trying to scare or be negative, but discussion with all potential
scenario's I can think of trying to help you make up your mind on how
to proceed
I've used double gaskets and only one lasted (not my vehicle, but
buddies) to fix one that had metal eroded by the gases
I'm not familiar with Fords, so just generic thoughts. Maybe visit
dome Ford boy racer sites
Easiest first...some times get lucky and it is just a loose nut/bolt
Get some high temp anti-seize and use it liberally
Most exhaust gaskets have metal layers and when you scrap off the old
gasket...be careful to not gouge the head or exhaust flange
The manifold will have doughnuts to the exhaust pipes (assume yours
do have them...check that out) and have new ones ready...in case
Make sure it is the gasket...cracked exhaust manifolds also behave
like this...some times
This is where I advise to buy OEM hardware. Have gone to grade 8 way
back in the day and they didn't make any difference. The heat will
de-temper them to become mud hen fasteners
For this kind of work, I had two 2x10 planks laid over the two fenders
(cushioned with foam/duct tape) and lay over the engine bay. Saves
my bad back
Consider removing the wheel well shield. Just a bunch of small sheetmetal
screws. Along with taking the wheel off...amazing how much room and
direct access that provides...sometimes...
Good luck!
Teamfour
If it is just a small crack in the manifold, smear some JB weld in it. I did this on an engine and it lasted for 50k miles.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 locker, 3,295 Payload
2014 Salem Hemisphere 282RK 7.8k lbs loaded, Equal-i-zer WDH
BurbMan
Three things you need to do a job like this:
1. An extra vehicle to drive for the week or so that you work on the truck evenings and weekends between all the other stuff that needs getting done.
2. Broadband Internet access to surf the forums and watch YouTube videos on "how to".
3. A Harbor Freight store nearby for all those sockets and wrenches that you discover you need because of the odd size and location of fasteners.
Golden_HVAC
Have you considered doing it yourself?
I think that the dealership is putting in a lot of shop time because they have had past problems with broken bolts that cause the job to eat up shop time. If you are very careful to move the bolt a little tight then loose, then tight again, you can get it moving without breaking the bolts.
Probably all you would need at this point is new gaskets, and then you can seal it again. No more leaks. You can also check with a local muffler shop, and see what they have to say. It might be a leaking exhaust system causing all that noise. I replaced the exhaust in my 15 year old 1975 F-350 and it became as quiet as my car! I loved that $800 cost! They put on a huge muffler, and went to a single 3" exhaust pipe for the 460" engine.
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
jj141979
jus2shy wrote:
mosseater wrote:
As I rationalize it in my head, (and my wallet) I know you guys are correct. To finally own it means another type of headache. That's just how it is.
Yeah, that tapping is pretty loud for the first 22 seconds, then it quiets down. Problem now is I'm smelling it stronger in the cabin than I ever have before, so it's going to need done for PA inspection. A strict no-no here. I'm also worried about erosion and losing a head or burning a valve. I just have that sinking feeling that it's going to be more than the $800, and that the other side will follow suit soon after. And, of course since the leak likely started at about 30K initially, the new gaskets aren't going to last long either.
I just love how we claim to be so much more advanced now, but we're still wrestling with the problems that remain unsolved since the dawn of the automotive age. Sealing exhaust manifolds??? Really? I guess a computer can't solve that one, eh? Sheesh!
The solution is building cylinder heads with integrated intake and exhaust manifolds (No gaskets, no bolts). I think Volkswagen or some European company and a few GM 4-banger motors moved that way. Sadly, you never know just how bad a problem is until you start peeling the layers of that onion. G'luck and hopefully it isn't anything too bad!
Chryslers Pentastar engines have the integrated exhaust manifolds on the them......a great idea!!
TV: 2010 Dodge Ram Power Wagon, Factory Brake Controller
TT: 2015 Coachmen Catalina 323BHDS, Reess Dual Cam
dodge_guy
$800 for one side?!!! I think you need to shop around a bit. maybe $800 for both sides. I can tell you it shouldn`t take a dealer that does them almost daily 8 hours a side!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
jus2shy
E'Aho L'ua
2013 RAM 3500 Crew Cab 4x4 SRW |Cummins @ 370/800| 68RFE| 3.42 gears
Currently Rig-less (still shopping and biding my time)
mosseater
Sunset Creek 298 BH
