Need your help, ideas
woodworker414
Good afternoon. We have a Silverado 3500HD, duals, 4x4. Kinda a high step up to the running board for Brenda. Not so much for me. Brenda is of short Stature. Well early this summer Brenda was diagnosed with Rheumatoid Arthritis. Stepping up to the running board is bit harder now. I came up with the idea of maybe adding a second step to the running board. 2 steps up into the truck. Any thoughts, help, ideas would be greatly appreciated.
Brenda and Bill
2020 Lance 1172, our traveling rig
2013 Heartland Landmark Mesa, 40', fifth wheel, we keep at our snowbird home in central FL, Bushnell, FL.
2014 Chevy Silverado LTZ 3500HD, CC, 4x4, LB, duals, DuraMax
21 REPLIES 21
TxGearhead
We just use a cheap one step plastic stool. Keep on the back seat with a towel under it.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
jimh406
Some of the auto fold down steps are pretty low. You might check those out.
woodworker414
#1Flyboy, thanks for the reply. I will check it out.
Brenda and Bill
_1Flyboy
Amazon has some other options!
Grit_dog
Nomad III
Nomad III
Not a cheap option, but Amp Powerstep XL's deploy at like 13" lower than the door sill.
woodworker414
bighatnohorse, thanks for the reply We have used a folding stool like the one you gave the link to I guess we will be using it more often now. Have to put some kind of string, strap on it so Brenda can pick it up when she is in the truck alone. And to be able to lower it to the ground when she wants to get out of the truck.
Brenda and Bill
bighatnohorse
We carry a small folding step in the Jeep for our now older friends.
And we use the same folding step for the camper when the first step is more than a single step.
You'd have to pick it up after each time she gets in the truck.
https://www.campingworld.com/e-z-foldz-folding-step-stool-12quot%3B---black-67053.html
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
