New Camper + Question on towing toys
Kalabin
Hey all,
Been a bit but my wife and have pulled the trigger on a new truck camper. We owned one in 2012, didn't have toys then sold it but we do now. My truck is a 2009 F350 Crew Cab V10 (3800lb payload). The camper (1994 dry, so 2800 wet) we are buying will need a 24" hitch extension to tow our 2013 Polaris RZR-4 900.
The RZR weighs in at about 1300lbs, the trailer I pull it on is an open utility trailer 7'x14' with a 3500lb GVWR. I have been told by multiple people to just pick up a reese or titan 24" hitch extension and go play.
I think the Torklift Superhitch is way over kill for what we would be using it for. Thoughts?
2009 Ford F350 V10 4.10 FX4 Crew Cab SRW, Timbrens, Leer Topper
27 REPLIES 27
STANG23L
How about just removing your rear jacks and storing them on the trailer. Thus keeping the hitch simple.
2014 Ram 1500 Eco Diesel
n0m4d
My trailer and the camper jacks do get real friendly when I turn sharp. I just don't turn sharp.
Kalabin
Update,
So got the truck camper and took the measurement. From the back of the hitch to the end of the bumper on my truck camper it is 24"
Now the issue I am running into is with an 18" extension + 2" shank and ball I can not make a hard 90 with the trailer or it will hit the jacks on my camper. I spoke to a trailer shop here and they are recommending a 18" extension + the Reese Hidden Hitch #80232, 16" shank. Which my current one measures 8.5" so that would get me to 24". My trailer is a GVWR of 3500lbs, only my RZR fits on it nothing else.
Anyone have to run something like this?
redink
I will add a vote for the Reese 80232. I used it with this rig for many miles of mountainous driving with no problem. 4000# boat, motor, and trailer. Sometimes heavier with a full tank of gas and ice. 55 gallon gas tank.
2012 Lance 825 on a 2008 Ford F-250 Diesel with Rancho 9000's, Fast Guns, Stableload Quick Disconnects for lowers and homemade Bumbers for the uppers, TokLift Tie Downs
jaycocreek
If the Reese 80232 15 3/4" ball mount will work,that is by far a better solution than a hitch extension with a 600/6000 lb rating.I measured and measured on mine and it will not clear the Lance bumper or I would have gotten that instead of an extension..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
fpoole
I had one, Towing a little ACE 900 with a 24" stinger from Torklift.
I was going to go with the Super Truss just to have it for future use but it would mean some big $$$ mods to the flat bed I put on. Hitch/towing, didn't know it was there, nor see it,hehehe 7x14 Alum mission...
I plan on doing the same thing when I get an RS1 buggy, not sure if open or closed, depends on $$$ at the time.
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10โ€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nโ€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
Kalabin
I'll need to get a measurement, you guys are right may not need a 24" extension. The camper is being delivered in July so I should know more in a bit. Have a little bit of time to get the truck set up.
Thanks for the advice.
jaycocreek
I have pretty close to the same thing..My camper is 9.6" long on a long bed F-350 and I have a Yamaha Rhino and an ATV trailer..My 18" receiver comes almost even with the bumper on my lance.My currant hitch extension is rated 350/3500 which is more than enough if I load the Rhino correctly.. Reese offers a solid bar 18" I should have bought instead with 400/4000 rating..I probably will still get it so not to worry about the hitch weight at all.
As you already know,it is pretty easy to gauge hitch weight as you pull your UTV on the trailer as it bucks a little as you go onto the trailer.
Super hitch for just that,heck no IMO.
Lance 9.6
500ah Lifep04
mkirsch
Nomad II
Nomad II
I agree. Do you REALLY need 24"? The ball doesn't have to hang way back behind the camper, unless you have a really weird trailer with a lot going on right above the coupler.
My camper hangs off the rear by 18", and I have a 14" extension, plus the shank, puts the ball just beyond the rear wall of the trailer. I have plenty of clearance and can turn as short as I want.
jimh406
Assuming the trailer weighs around 700 lbs, you are looking at a 2000 lb tow. It's possible to use the extension, but make it as short as you can. 18 inches would be better. You are going to be weight challenged once you add the tongue weight no matter if you have a Superhitch or not. That would probably be your more pressing issue.
Here's another related thread on extensions. https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29661175.cfm
n0m4d
I bought a TC specifically so I could camp and tow trailers. I think it really is a factor of how far your camper hangs off the back as much as weight. I just use a longer standard hitch (Reese 80232 16") and it's all good, further than that I'd be inclined to go with a Supertruss. This is the heaviest thing I tow with my 2000lb camper on the truck:
deltabravo
I'd go Superhitch and Supertruss.
SidecarFlip
I think so too. I just used a hitch extension on my 350 to pull my trailer and quad. Just watch your tongue weight and where you place the ATV on the trailer.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
