โJun-10-2020 06:59 PM
โJun-11-2020 09:24 AM
midnightsadie wrote:This has nothing to do with the OP's post but I find this comment bemusing. When dealing with any salesman, I hold all the cards. The salesman gets nothing (except wasted time) until I say "yes". The pressure is on him to meet my requirements. Until then the key word is "No". I feel no pressure; as long as it's my money it's my way or the highway.
find a great used rv, stay away from high pressure sales dealers...
โJun-11-2020 07:10 AM
APT wrote:
Going from a low walled trailer to a high walled trailer is significant. There is a lot more air resistance which means more power, fuel, and heat. If you want to keep that MDX, then I recommend sticking to under 3500 pounds GVWR (single axle) TT. Also, flush all the fluids and install a heavier duty transmission fluid cooler. If you want something heavier and high walled in the 5000 pound dry range, then I recommend any half ton SUV. Something with at least 6-spds in the transmission. Pick your favorite brand, but again you need the HD trans cooler.
Brand does not matter with respect to quality of construction and assembly. They are all about the same (not good). If you are handy and experienced with your prior RV, then I recommend never visiting an RV dealer for repairs/maintenance.
Historically, you will find the best prices for new RVs in the midwest. IF you are willing to drive to Ohio once to pick or NY, there are some "Wholesaler RV" dealers that offer discounts around 30% off. Check out RV Direct for example.
โJun-11-2020 06:43 AM
โJun-11-2020 06:36 AM
โJun-11-2020 05:35 AM
โJun-11-2020 04:58 AM
โJun-10-2020 07:45 PM
ADK Camper wrote:
Can't respond to all your questions, but for what it's worth I'll share some of my opinions. I've had a funfinder for 9 years. It's been relatively trouble free. Sounds like you're looking for a "couples camper" I suggest you Google that to get some ideas. I suggest giving priority to a walk around bed, and a sofa. If seating is limited to a dinette, I believe you'll find it uncomfortable for extended seating (think rainy day). A sofa AND dinette may be very hard to find in the size trailer you want unless you pick a floorplan with a Murphy bed. We do not have a dinette and don't find that to be a problem. We use a small gate leg table pulled up to the sofa, or sometimes we use folding chairs. Definitely insist on a slide: it will really open up your floorspace.
โJun-10-2020 07:29 PM
