โJan-27-2016 05:48 AM
โJan-28-2016 04:34 AM
โJan-27-2016 05:59 PM
โJan-27-2016 05:46 PM
โJan-27-2016 05:27 PM
โJan-27-2016 05:06 PM
โJan-27-2016 01:09 PM
โJan-27-2016 09:25 AM
โJan-27-2016 08:45 AM
โJan-27-2016 08:11 AM
APT wrote:
There should be a sticker on driver's door with axle code. You can decode this on page 3. Should be the same for 2009. They are the same back to my 1999 F-150.
You have the 3V 4.6L/6-spd and likely 3.55 or 3.73 axle. That's fine for power and certainly better than the prior generation 4-spd 5.4L. I expect you should be good for 5000-ish pounds dry RV. Ford offered an integrated brake controller, or there are decent aftermarket proportional controllers for $100-150 (Tekonsha Prodigy P2/P3).
I believe all F-150s have transmissions coolers. The HD towing package got an upgraded one. You may want to check with a local transmission shop to access your cooling needs. This is important when towing any high walled trailer.
โJan-27-2016 07:53 AM
โJan-27-2016 07:44 AM
โJan-27-2016 07:12 AM
โJan-27-2016 07:04 AM
