No Shower Surround
rvhippo
I'm buying a new 2015 Jayco X213 and the shower does not have a plastic surround. The shower stall is just what looks like vinyl wallpaper with caulk at the corners. I've noticed that there are several staples through the wall paper. Will these staple holes allow water to get behind the wall paper or rust when the shower is used?
I've looked at five new X213 trailers and they all have these staples through the wallpaper. Two actually had wood screws poking out through the wall paper in addition to the staples.
Is the design such that the entire wall is waterproof or is just the wallpaper waterproof?
Thanks in advance for any advice.
19 REPLIES 19
Lantley
No surround would be a deal breaker for me. Simply put, a shower surround is a basic minimum requirement in my book. If the Jayco model did not have a surround I would keep shopping until I found a unit with a surround.
Mike_Up
wmoses wrote:
Saving weight these days means selling trailers; its as simple as that.
That's true. It's not just Jayco as I consider them the better made campers. I've seen a lot of other brands without a shower surround.
These makers skimp on these features to keep cost and weight down. On many makes, a spare tire, oven, shower surround, larger propane tanks, DSI water heater, Double door refrigerator, microwave, and such are options that need to be bought in packages or separately. By not including them, they shave off a lot of money and weight, but make the camper pretty inconvenient to use. Had a pop up without those anemities, not having that in the travel trailer.
2019 Ford F150 XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 9.75" Locking Axle, Max Tow, 1831# Payload, 10700# Tow Rating, pulling a 2020 Rockwood Premier 2716g, with a 14' box. Previous 2012 Jayco Jay Flight 26BH.
wmoses
pasusan wrote:
We take showers in it all the time - it doesn't leak and still looks like new after all these years. We do use a soft and flexible squeegee on the walls after showering.
I agree. That was what we did (and still do) and the wallpaper on the old trailer was in the same condition as it was after 3 years, as the day the trailer was bought. The wall paper IS durable if cared for properly. Is it as good as a shower surround - obviously not. Is it lighter than a shower surround - absolutely, and that is why it is there. Not because Jayco is cheaping out on their trailers.
Jayco quality is a bit higher than most, IMO, although still nothing to brag about (as is typically the case with this industry). Saving weight these days means selling trailers; its as simple as that.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
pasusan
Ours does not have a surround - just the wallpaper. There are no screws or staples though. :R
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
Tvov
That just sounds odd to me. We use the shower all the time in our TT. Not having a plastic surround just seems cheap... especially from Jayco?!? They have one of the best reputations in travel trailers. Hopefully they can keep that reputation.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
chrispitude
calamus wrote:
I glued frp to the walls of my travel trailer. It has worked well for years.
Neat idea.
Mike_Up
I passed on models that didn't offer a tub surround. Found out it would be about $500 to install one.
What I was told by the dealer is that the wall paper is waterproof but it will eventually be ruined by cleaning. If you let the scum collect on it and never clean it, it may last. BUT that sounds pretty disgusting. That's a shortcut that should had never been taken but so many companies are doing it on cheaper lightweight models it's hard to get away from.
dodge_guy
Our 05 Cherokee didn`t have a surround either. the surround was an option. with everything caulked and sealed it should be OK. I don`t remember any staples through the wall though. even still you could easily dab a bit of caulk over the staples to seal them.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
doxiluvr
I don't think I would buy it or at best I would have a lot of questions about it.
2006 Keystone Sprinter 300fkms
2007 Silverado 2500 Duramax Diesel 6.6 - Allison 1000 6 spd. auto. tran.
1 high school sweetheart hubby - 1 ChiWeenie - Abby
4 grown kids, 6 grandkids, 2 great-grandchildren
1 2007 Yamaha v-Star 1300
gheicher
Dtaylor wrote:
This company sells all sorts of shower stuff. https://www.randgsupply.com/ (I don't know why but after posting, I cannot access website)
Try www.randgsupply.com. This is without the request for a secure server (https://).
Dtaylor
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
dadmomh
Over the past few years this question has come up from time to time, so must be the way Jayco is doing things these days. I wouldn't even consider using the shower without some type of surround. The one in our ROO and now in our Rockwood have prefab molded panels that are trimmed with some sort of vinyl seal at the top, but left unsealed at the bottom. Consensus seems to be that is to allow for any water than might get behind to drain out. Also, the shower pan has a lip that this surround fits over, so water getting behind would be a slim chance. Personal opinion is that it not only looks cheap but is just a problem waiting to happen. Adding the surround as suggested above is likely your only choice, but you're going to have to cut and trim it to fit well and be completely sealed. Before signing on the dotted line, I would ask the dealer to confirm that there is no surround available to be added or special ordered. I don't care for the idea of plain wallcovering and water.
Trailerless but still have the spirit
2013 Rockwood Ultra Lite 2604 - new family
2007 Rockwood ROO HTT - new family
2003 Ford F-150
4 doggies - We support Adopt/Rescue.
Sam, you were the best!
Cubbie, Foxy, Biscuit and Lily - all rescues!
westend
tragusa3 wrote:
what is frp? I need something on mine!
Fiber Reinforced Plastic--It is sold in 4' x 8' sheets at the Big Box stores. Last time I bought sheets it was around $20/sheet. Pick up the right surround glue when you buy your sheets. Some stores will have it in colors and it usually comes with one side textured, one side smooth.
'03 F-250 4x4 CC
tragusa3
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
