Does the non-turbo have the same compression ratio as the turbo engine? Often when a manufacturer adds a turbo they reduce the compression ratio to keep cylinder pressures in check. If they did this, and I don't know that they did, and you don't install a turbo you will have quite a bit less than 27 HP.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
