Odometer
monkey44
Nomad II
Nomad II
Wondering if the odometer captures mileage with a mechanical reader or with something off the GPS?
In older trucks, we had that cable attached to the drive shaft or end gear in the transmission. Today, I'd expect it to be different, but am not sure.
Reason: In the past also, when we up-sized tires from, say a 245 to a 285, the odometer would not read accurately unless you changed the readings.
Just up-sized from 265 tires stock to 285 tires, and want to know how that effects the mileage reading.
Anyone know for sure how the mileage data is collected? Thx M44
BTW: We traveled 7424 miles on 689 gallons - 10.775 MPG with 4000 wet weight camper load ... 2015 Chevy 4x4 w6.0L and 4.10 RE
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
8 REPLIES 8
wilber1
Not all manufacturers are the same, some have a pickup at the transmission and some at the axle. My 01 Dodge 2500 had a pickup on the rear axle. You could change a rear end ratio without recalibrating the speedo but you had to if you changed wheel diameter.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
TurnThePage
On my 97 F150, I changed out a gear at the end of cable that connected to the transmission. That's totally old school. Anything in the last 10 or 15 years will have to be modified digitally on the vehicles computer. Dealers can do it, or you can buy a tuner that can do it.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
2oldman
Allow me to google that for you.
How stuff works -odometers.
Bumpyroad
compare circumference of both which will give you how much you have gained
bumpy
Triker33
To find the difference. Check the odometer against 10 miles of mile markers a couple times. In 10 miles it may only register 9.8 now.
I went from 235/80/22.5 to 275/70/22.5 and lost .1 every 10 miles or 1 mile every 100 driven.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
azdryheat
Not all trucks come with GPS. Doubt they would have two different mechanisms.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
mbopp
Not sure, but I believe speedo calibration is handled by the drivetrain computer. I think a dealer tech can put in a calibration based on tire size and axle ratio.
2019 F250 XLT Supercab
Just DW & me......
Bionic_Man
I believe they still go off of some sort of tire rotation. If you changed your tires, in order to be accurate, you will need to have your speedo recalibrated.
Pull out a GPS and check your speed on the highway. I bet it is now off.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
