Oct-17-2019 05:19 PM
Oct-20-2019 08:26 PM
Oct-20-2019 10:12 AM
Oct-20-2019 09:36 AM
Oct-20-2019 08:15 AM
chiefneon wrote:Kayteg1 wrote:
Get Fumoto valve and you will smile each time you drain the oil.
Howdy!
Those are great if you change your oil yourself. I had one in my truck when we first started fulltiming and had places refuse to do the work with it installed are I’ed go back to using one.
“Happy Trails”
Chiefneon
Oct-20-2019 08:08 AM
Oct-20-2019 07:14 AM
Oct-20-2019 07:05 AM
akaPedro wrote:
Was it done via a pit....or a lift ?
Oct-19-2019 04:15 PM
Oct-19-2019 04:11 PM
Grit dog wrote:chiefneon wrote:
Howdy!
Just had mine done at Walmart. Shell Rotella T6, filter and lube $80.00. In and out in about 30 minutes.
“Happy Trails”
Chiefneon
They put $75 worth of juice and parts (on sale) into your truck for $80? I’ll take everything I own there!
Oct-19-2019 04:01 PM
Oct-19-2019 02:26 PM
Oct-19-2019 02:13 PM
Oct-19-2019 02:03 PM
Oct-19-2019 01:57 PM
ajriding wrote:
Those quickie oil change shops use doggie doody low grade oil that I would never put in my engine. Especially if you have a diesel do not ever let a quickle place change your oil, they often even use a suction tube stuck down your dip stick to suck a lot of oil out, not nearly all, and put the poor quality oil in.
Bring your own oil with you, and filter.
Call and find a operator owned place who is willing to use an oil pan and crawl under to drain the oil. The big trucks like these are quite easy to crawl under.
He will spend 90 seconds pulling out the drain plug, go back and do something else while it drains, then spend 30 seconds putting it back in, another 20 seconds pulling the full oil out, and 1-2 mins pouring the oil into the barrel and putting his pan and wrench back. Then 2-3 mins putting the new oil in and just a few mins to put on the filter, before adding oil hopefully.. He will probably spend more time talking to you about it all than it takes him to do it, so leave him alone.
Oct-19-2019 10:56 AM
