OK to carry gas can on tongue near battery, well secured?
profdant139
I carry a small gas can for my generator, usually in the covered cargo bed of my truck. But it is in the way. I want to put it on the tongue of the trailer. I can easily build a secure place for it to sit -- that is no problem, and it is not going to move around.
My concern is the battery, which is mounted on the tongue in a plastic box. The idea of anything electrical right near a gas can is troubling. Yes, the gas can is the modern type that supposedly does not give off fumes. And yes, the battery is in a box and does not give off any sparks, that I can see.
But I am one of these ultra-cautious people, so that is why I am asking. Would this setup create any risk of fire or explosion? Or am I worried about nothing?
Thanks in advance for your input.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
18 REPLIES 18
TurnThePage
I just ordered a Stromberg-Carlson cargo tray for the tongue of my trailer. I'm considering putting my generator on it, but may end up with all the other odds and ends going there. It would be an ideal location for a small gas can to ride. In my humble opinion of course. ๐Ÿ™‚
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Jay_Coe
Can you imagine if the internal combustion engine was just being invented now? "Well we have this idea for a unit that will power everything from your personal transportation to your lawn and garden tools. Only thing is, you'll have to have a 20-40 gallon tank of explosive, flammable liquid under your vehicle and you'll have to keep containers of the stuff in your garage/shed to power your yard equipment". Lawyers and consumer protection agencies would never let such a ludicrous idea get off the ground!
Legal disclaimer: Trust me, I know everything!
profdant139
Dennis, I got DW involved late this afternoon, and her advice was to leave it in the truck. Her reasoning is that if we put it on the tongue, it has got to be strapped down very securely, of course. And we store other things on the tongue -- the chocks, some extra blocks of wood for leveling, the sewer rinse hose (not the fresh water hose).
So if I mount the can on top of all that stuff, I have to undo the straps on the gas can just to get to the other stuff. Too much of a hassle.
I reluctantly agreed with her, so this project is probably not happening.
About our trailer
Executive45
How about if your safety chain becomes unhooked, either because you forgot, it broke or some numbskull disconnected it while you were having breakfast. That will cause some nice sparks. How much room in the back of your truck does a one gallon can take up? Just wondering if you're overthinking this whole thing....Dennis
Lwiddis
As old guy said โ€œpersonally I don't like the idea at allโ€
Iโ€™m fearful of only a few things. Gasoline is one of them. Just the right circumstances...boom!
profdant139
The points about the quality of the container are well-taken. This gas can only holds a little more than a gallon but it was very expensive -- I think California now requires elaborate vapor containment hardware on these tanks. It works, too -- I can't even smell the gas fumes when I shake the gas can.
About our trailer
hotjag1
If you follow all the safety comments that have already been suggested and a secure gas can, it seems like an okay solution.
After all, your electric fuel pump is submerged in gasoline and seems to be an okay solution:)
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
ndrorder
The lower explosive limit of gas is a little less than propane. Be sure there isn't anywhere for leaking gas to pool and the fumes can readily disperse both up and down.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
Old-Biscuit
It's not as if you are carrying around an open bail of gasoline.....it is in a 'legal' gas container that doesn't leak.
Biggest issue is finding a decent gas container....majority are junk
old_guy
sure it's fine, do you feel lucky punk? personally I don't like the idea at all. one spark, a wreck, I see a large fire ball in your future
valhalla360
Nomad III
Nomad III
As long as it's not mounted above the battery where a leak would fall directly on the battery box...no worries.
You realize every gas powered car has a battery and electrical components in the engine bay.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
There is no perfectly safe place to carry an extra gas can in all conditions.
Mounted securely on the tongue is as good as any place. Better than attached to the rear IMO.
sgip2000
Many batteries are near propane tanks as well.
colliehauler
Should not be a issue, that's where the propane is located as well. Would just make sure it is secure in a good quality container.
