The platform that raises my camper a little is a 4x8 sheet of rigid foam insulation. Weighs nothing, works great. I should just attach it to the bottom of my camper.
Those used car extended warranties have traditionally been dealerships best moneymakers.
F450s usually ride terrible when empty, but are the reigning king of camper haulers.
They usually turn tighter than F350s can.
The area of interference that comes up putting older campers on newer trucks is the little kickout ares for the bathroom, the part that goes inside the tailgate opening but behind the wheel well.
I donโt know what camper you have but generally campers 1988 on up are made to fit, because thatโs when GM started the narrower-than-65โ tailgate thing. (Followed by Dodge in โ94 and Ford in โ98.)
If you have that problem itโs possible to fix, you need to narrow that kickout about two inches.
Sometimes you take it apart and find itโs easy to do, sometimes you have to do like I had to do and have to section and re-fiberglass the shower enclosure a little.
Driving a late model F450 with a 9.5 camper will be an extremely pleasurable experience.
Iโve driven F450s and F550s with ridiculous amounts of weight in them and they just handle it like a boss.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
