cooter4x wrote:
Ran into this situation... the wiper seal that attaches to the opening is totally rotten. Does anyone have any suggestions? Can i replace the wood with minimal disturbance?
Thanks in advanced...
![](https://farm2.staticflickr.com/1814/43125140485_b2f83e4cde_z.jpg)
![](https://farm2.staticflickr.com/1831/43312269514_d9537ed56a_z.jpg)
![](https://farm2.staticflickr.com/1791/30162676558_913997f1f2_z.jpg)
Nope, no way can this be "fixed" with "minimal disturbance".
Judging from the amount of sag in the third pix I suspect your have severely compromised roof structure back to the A/C unit.
Your options are remove interior paneling back to good wood structure, this most likely will also result in the need to remove some of the ceiling paneling back to the A/C unit.
Once paneling has been removed, then you can assess just how bad the rot is.
You will then need to remove the rotted joists, wall studs and header over the slide, sistering new joists, studs and header on to the remaining good ends.
Replace water damaged insulation and put new ceiling and paneling back up.
Not a job for the faint of heart or one that is in a hurry, but it CAN be done.
If you are handy with tools and don't mind the work it can be done for just your labor and material costs.
Many on this forum WILL disagree with the repair/DIY approach and would simply scrap/sell it. If you like it and got it for a cheap price and are handy with tools and have lots of time you can make it a gem again for less than a new trailer.
If you had to sub this out to a repair shop and pay the labor costs on top of materials it would not be worth it. In this case, best to sell or scrap and move on.
The big unknown is just how far does the rot damage go, water can go a long, long ways from the leak and is often well hidden for a long time before the damage shows..
