May-13-2013 09:32 AM
May-13-2013 06:50 PM
jerem0621 wrote:45Ricochet wrote:rhagfo wrote:
Keep in mind the F350 is SRW, not going to have a 9,000# axle rating, more like 6,100 to at most 7,000#.
Same axle as a DRW Ford so it IS rated at something over 9k, only the tires are holding it back from it's full potential.
Pretty sure the DRW has a Dana 80 and the SRW has a Sterling 10.5.
May-13-2013 06:36 PM
May-13-2013 05:57 PM
rhagfo wrote:
This is the result of the GVWR being tighter to the total GAWR of the truck. Now days that is running between 90% to 95% of the total GAWR, so it is possible to exceed the GRAWR without exceeding the GVWR
May-13-2013 05:41 PM
May-13-2013 04:55 PM
May-13-2013 04:36 PM
May-13-2013 03:38 PM
May-13-2013 03:36 PM
May-13-2013 03:23 PM
rjstractor wrote:NC Hauler wrote:
OK, I'm confused...He stated he's NOT over his GVWR (gross vehicle weight), but IS over his RAWR by 400#
Did anyone not catch this...If he is over his RAWR he's WAAYYY over his GVWR..unless he meant he wasn't over the trucks GCWR...but again, I get the impression that he IS over his trucks RAWR, but because his tires will handle more weight, he should be ok
Not necessarily over on his GVWR. The GVWR on a newer SRW F350 is 11,500. So, if he is 400 over on RAW, is he is running less than 4K on his front axle he could be less than GVWR. Granted, that is pretty light on the front end. I myself am surprised no one asked where the kingpin placement is in relation to the centerline of the rear axle. If it's too far back he could be unloading the front axle, and if that's the case moving it forward to just ahead of the rear axle could solve all his weight problems.
May-13-2013 03:10 PM
May-13-2013 02:07 PM
May-13-2013 01:17 PM
howardwheeler wrote:
I have a 2012 F 350 Powerstroke SRW.
May-13-2013 01:07 PM
rhagfo wrote:45Ricochet wrote:
I was a bit confused also Jim with the weights and ratings :H
That rear axle rating should be more like 9000 lbs I would think. The only limiting factor is the tires. I agree even the guys that use axle rating instead of GVWR usually don't go over their RAWR. In general a newer Ford F350 should be maxed out at about 3k lbs of pin weight.
This is the result of the GVWR being tighter to the total GAWR of the truck. Now days that is running between 90% to 95% of the total GAWR, so it is possible to exceed the GRAWR without exceeding the GVWR.
May-13-2013 01:00 PM
