โAug-27-2017 04:17 PM
โAug-30-2017 05:57 PM
โAug-29-2017 07:45 PM
BB_TX wrote:
Best permanent method is to add a new external weatherproof coax connector, a new RG6 coax from there to a new inside coax wall plate, and a new RG6 from there to the sat receiver. Due to the TV location and cabinet arrangements it was a simple process on mine and all hidden from view.
โAug-29-2017 07:32 PM
ZeeLet50 wrote:
I told my friend that as long as the cable is RG6 and any splitters inline should have the MHz rating to pass satellite he would be good. he does have a Keystone Hideout '17 so chances are good.. There is a splitter for the inside/outside tv he has to check.
โAug-29-2017 06:53 PM
โAug-28-2017 04:24 PM
Atlee wrote:
Jayco claims the cable inlet is good for satellite also. They claim they use RG-6 cable through out.
Haven't tried it, so don't know for sure.donn0128 wrote:
Generally speaking, no. Mfgs use cheap coax and lots of low quality splitters. All of which degrade high quality signal needed by sat receivers.
โAug-28-2017 01:28 PM
jorge1958 wrote:
I find this satellite thing kind of interesting. What kind of initial costs are involved on one of these. I really would like to have one but worried it might be to expensive. Any feedback would be appreciated. thanks
โAug-28-2017 01:02 PM
ZeeLet50 wrote:
Got a friend who is going to get a satellite dish for the camper. can he use the external cable connection on the camper to run the signal to his TV assuming the amplifier is turned off? if not what is the best method?
โAug-28-2017 11:36 AM
myredracer wrote:
Our TT came pre-wired for satellite TV. I couldn't figure out how the factory ran the cable and where a splitter is. There's an extra jack on the ceiling above the TV at the dinette and also in the bedroom (in addition to regular coax jack). I have no idea where they expect you to put a sat. receiver.
Our external sat. coax jack is behind a bank of kitchen drawers and I removed the factory coax and ran new high quality coax up to the sat. box which sits on top of the kitchen cabinets through the lower cabinets and up inside the wall of the pantry. From the receiver I ran an HDMI cable through the ceiling over to adjacent to the TV where the radio is. There is a large grommet beside the radio for the component cables to the TV and the HDMI cable runs through that. All new cable is fully concealed. I changed out the single receptacle at the microwave for a duplex type and the receiver plugs into that.
I'm curious where other folks put their receivers? Luckily with the arched ceiling we have, there is an open space above the kitchen cabinets that is just tall enough for the receiver and is the perfect place. In later model years of our TT, KZ filled in the opening with a piece of luan. Absolutely no place in the bedroom for a receiver other than attaching to the ceiling...
โAug-28-2017 10:42 AM
โAug-28-2017 10:14 AM
โAug-28-2017 09:05 AM
โAug-28-2017 08:48 AM
โAug-28-2017 05:11 AM
โAug-28-2017 05:04 AM
