Question about WD Hitch adjustment???
DarbyWalters
I have the PRO Series WD (bars with chains) and am wondering about the chain link adjustment. On the last chain link I get this:
Truck Fr Axle 3080 (rated 3750)
Truck R Axle 3800 (rated 3850)
Trailer Axles 6500 (GVWR 8500...Empty 6475)
I would like to transfer a bit of weight to the Front Axle of the truck...so...do I go another link which would raise the rear of the truck a tad?
14 REPLIES 14
jerem0621
rbpru wrote:
Here is one for you, when I picked up my trailer, during the walk through, the dealer showed me how to work the Blue OX WD hitch. He counted 7 links and said I might have to adjust a link when loaded so that the TT and TV sat level. Simple enough, drove it home and parked it in the snow.
A couple of months later I hitched up and counted the 7 links but something was wrong. :E I needed 9 or 10 links for a level trailer!!:h
Well eventually it dawned on me, the dealer counted links from the bar to the frame mount. I was counting links from the end of the chain to the mount. 😮 :S
Life has a way of reminding you that you are a mere mortal. :W
Easy to do! Many people will mark the link they usually use for their loaded trailer. Many ways to mark a link.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
rbpru
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
BarneyS
Take a long look at this thread if you have not already done so. 🙂
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
coolbreeze01
I measure at the front and rear bumpers MT. Hook up and measure again. Now set the chains on different links, remeasuring.
Doesn't give weight in pounds, but indicates weight transfer.
2014 Sandsport 26FBSL
_tiredTeacher
APT wrote:
The ones that count are the ones under tension. Every WDH manufacturer that uses chains lists requirements for links under tension.
And if you put your rig into a tight turn, stop, get out and look at the position of the bars, you'll understand why.
I, too, vote for putting a washer in the hitch head and keeping the bars parallel to the trailer frame.
Teach
Wright and Penny
2010 Tundra 4X4
2014 Rockwood 2604WS
"Life is a cruel teacher. She gives the test first; the lesson then follows."
jerem0621
Would add another washer to the hitch head and hang with the same link
TT - Zinger 270BH
~Walt Disney~
APT
camp-n-family wrote:
I count the links from the other end, the ones hanging. The more that are hanging loose (or used up), leaving fewer between the bar and frame, creates more tension. For example, if I have 8 links to use and start on the first (farthest from the bar) I have very little tension. For more tension I "use" up more links and go to the 4th....
Don't do that. The hanging links are not used up. They have no value. The ones that count are the ones under tension. Every WDH manufacturer that uses chains lists requirements for links under tension. Like Reese I believe says 5 links under tension minimum, no fewer. Fewer links under tension = more weight distribution to front axle and trailer axles.
OP, the weights you provided are helpful but you need to weight at least 3 times to understand how well your WDH is adjusted. Depending on your truck, your goal is to adjust the WDH such that the trucks front axle weight about the same as when the truck has no trailer attached. So if the truck's front axle weight was 3400 pounds empty, then you probably need more WD. If it was 2800, then you applied too much.
2017 Subaru Outback 3.6R
camp-n-family
Generally the more links under tension, the more weight transferred.
Are you sure about that???
For the Reese system that I have, it is the exact opposite. The fewer links that I have under tension, the shorter the distance between the trailer frame and spring bars. Therefore, more tension would be applied to the spring bars and ultimately, more weight distributed to the front axles.
Maybe I'm talking about a different type of system geometry than the OP. If so, my info doesn't apply.
I should maybe re-word it to "the more links used up, the more weight transferred". The way you explain it is also correct. I count the links from the other end, the ones hanging. The more that are hanging loose (or used up), leaving fewer between the bar and frame, creates more tension. For example, if I have 8 links to use and start on the first (farthest from the bar) I have very little tension. For more tension I "use" up more links and go to the 4th....
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
DarbyWalters
Ivylog wrote:
What, someone actually weighed their rig. In a previous post your trailer loaded weight was 7200 so yes I'd go one more link.
Yep...some people on here actually ask for advice and follow it...the wonders never cease!!! I will be going one link "tighter" for lack of a better term and see what the results are. The trailer still is oh so slightly nose down at the moment.
Thanks again all...
Dakota98
This ought to be an interesting post. My thoughts, the more links used, the more weight transferred to the front axle. My set-up as weighed has 2600 lbs on the front axle not hooked up & 2540 lbs front when connected to the TT.
ON EDIT: I stated this backwards. I have 4-links under tension, & the bars are parallel to the frame.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
GrandpaKip
Yep, the fewer links between bar and frame, the more weight distribution. Your truck manual should tell you about what the difference should be on the front axle between loaded and unloaded.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Beachums
2004 Ford Expedition 4X4 3.73 w/quick shift kit
Reese DC Straight Line/ Prodigy P2 Controller
2010 Coleman CT 250 GS
Ivylog
Upgraded with a 08 HR Navigator 45’...
camp-n-family
Generally the more links under tension, the more weight transferred. It would be best to know what the weights unhitched are to know how much weight is being added to the rear axle and reduced from the front once it is hitched. This will give you a better idea if your hitch is set right and is transferring enough weight. Some manufacturers suggest returning the front axle back to the unhitched weight while others (like Ford) suggest returning 50% of it.
Hitched by Hensley
