No apologies needed. If your camper is white, I can all but guarantee the caulk was white when it was applied.
3 things that will make re sealing the camper, or anything you caulk, house trim, bathroom, etc.
Good prep. Like mentioned above.
Quality caulk.
Learn how to caulk without using your finger to "smooth it out" everywhere. Start w the smallest angled cut on the tube you can get away with and do all the smallest seams first. Then if you need a wider bead in areas, cut it wider and do those areas.
Maybe I'm sensitive since I just spent hours scraping off old beads of caulk today both factory and previous owners that should have been 1/8 to 1/4" but were smeared 1/2" on to the surface.
Hope this helps.
Oh and a cover will do wonders to keep the sun from prematurely crisping the sealant if you can't store it inside when you're not using it.
