Questions abou t new (to me) Northern Lite
bkenobi
I just picked up my first TC last week. I'm going to be taking my first trip next weekend and need to get a couple things figured out. The first is critical, the second is maintenance that will come into play down the road.
1) The NL TC is a 2007 10'2" RRQ (rear dinette, queen bed). It was kept in great condition by the original owner fortunately. But, the TC did not come with a sewer hose. There is a hole/door in the side of the camper that is 17" deep that I've been told is for storing the dump hose. I picked a relatively cheap one up from Walmart but found it does not fit either. It's both too large diameter (the hole is 3-3/4" diameter but the hose coupling is closer to 5"). Secondly, the hole is not deep enough to hold anything longer than 5' and can't hold the 90deg bend. I probably need to contact NL about this, but what the heck am I supposed to use in order to dump sewage without adding an aftermarket hose holder tube?
2) The Happijacks are functional and in good visual condition. However, there are some chips/cracks in the paint that some rust is coming through. What should I use to paint this? Since it's regularly going to get wet and has to take some abuse, I was leaning towards marine grade paint, but a recommendation for what others do would be nice. I'll probably look into contacting Happijack to see if they have a suggestion, too.
38 REPLIES 38
Photomike
The sewer hose was always a challenge with my NL. The first month I owned it I was driving from one campsite to another and when I arrived for the night I was missing the sewer hose, seems the size of the tube for storage was too short and when pushed in it the hose became a spring and on one of the bumps the door opened and the hose sprung out. Was not too sad as it was in bad shape so I bought another and kept an eye open when driving and fortunately saw it do the same thing on the next trip. So I went home and lengthened the storage tube to stop the high velocity escape :B
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
bkenobi
The bumper has welded caps so it would require modification to use. It's also pretty small and unlikely to fit a hose with the fittings.
Homeless_by_Cho
maxum1989 wrote:
You don't have the rear bumper you can use for your sewer hose?
Only a plain sewer hose without any plastic ends on it will fit in their bumper. I mounted a vinyl (plastic) hollow fence post on my truck bumper and carry my Rhino hose with fittings connected in that.
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
maxum1989
2008 Chevy 2500hd Duramax/Allison
2006 Wildcat 27 bhwb
2009 Lance 830 *Sold*
2011 Northern Lite 8.5 *Sold*
bkenobi
I figured that box might be too small for anything useful. If I fit a 5' hose in there, I'd still be well short of the dump station I stopped at yesterday for measurements. It looks like I can get within 5' of the hole, but I'd need around 10' to use it really.
How do you connect the DIY fence post to the camper? I could put it under the side by the truck rail or on the forward side of the bumper. I don't like the idea of drilling into the shell if it can be avoided.
pastorbillv
For my sewer hose, I have a shallow, square, plastic basin/bucket that I put in my empty generator compartment to put my sewer hose in. I put the grey water hose with it. works fine.
Bill
2004 Bigfoot 29G (Love the garage!)
2017 Northern-Lite 10'2" SE on F-350 (CC, Dually, 4WD, Boss)
Wardster
Most of us have fabricated a sewer hose holder out of a white vinyl fence post and a couple of caps. The sewer hose storage in the NL TC's, even in the new units, isn't capable of holding the sewer hoses that I have found available at the stores around me.
With respect to your Happijac question, their customer service was great to deal with.
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
guidry
daily double wrote:
Good luck contacting Happijac!! :R
I too just bought a used Northern Lite and when I contacted Happijac, they responded quickly and the tech was very helpful. Maybe I just got lucky but my experience was good.
daily_double
