Quick Winterizing Question
jhfxrtleeh1
I know...I know... yet another newby winterizing question. I understand about emptying the fresh water, blowing out the lines & pump and adding antifreeze to the sink traps, but what (if anything) do you do to the holding tanks (other than empty them)?
12 REPLIES 12
jhfxrtleeh1
Thanks gang. This is about what I thought, but since this is our first TT and we bought it used with no instructions, I wanted to double check. You guys are the greatest!
fallsrider
I almost forgot the toilet myself last week.
hohenwald48
And the outside shower.
And if you have a pushbutton pullout sprayer on the kitchen sink be sure to run AF thru both the spray and stream sections.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Chuck_thehammer
and outside shower.. if available..
Bigbird65
When you are blowing out the lines don't forget to step on the commode flush peddle. I almost forgot to do that this year. If you have a black tank cleaner line be sure to blow it down.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
janstey58
AF in the tanks will provide liquid on the waste valves and keep them lubed up over the winter time, and not dry out.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
korbe
After I run the pink stuff out the faucets and before I pour more into the traps, I empty the holding tanks.
beemerphile1
The winterizing is to prevent water freezing, expanding, and rupturing pipes and fittings. An empty tank won't freeze.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
BB_TX
A little water in the bottom of a large tank will not hurt anything. I pump antifreeze thru my lines and some goes down the drains into the emptied tanks. It will be somewhat diluted but will not cause problems in freezing temps due to the small amount.
cbshoestring
For me....
Fill then empty.... Repeat. End up with an empty tank that is as clean as possible.
I then add pink stuff to all the traps (knowing, as others have said, that some of the pink stuff will end up in tank). I add a little extra down the toilet into the black water tank. Kinda like you would during normal use with water (maybe blue stuff) but I use anti-freeze (no blue stuff) to keep the bottom of the tank from drying out......just in case there is some "accumalation" in there.
SoundGuy
In the course of adding pink to the toilet some of it is inevitably going to end up in the black water tank and work it's way down to the waste gate. Likewise any pink added to the sinks & shower is going to fill the traps, any excess will drain into the grey water tank and work it's way over to that waste gate, a good thing in both cases. Fresh water holding tank - just empty it as best you can and forgetaboutit. ๐Ÿ˜‰
2012 Silverado 1500 Crew Cab
RVcircus
I dump antifreeze down the sinks and put some in the toilet. I consider it cheap protection at a few $/gallon.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
