โApr-27-2014 09:34 PM
โSep-12-2014 09:36 AM
Perrysburg Dodgeboy wrote:
yr2017 you are the first one I have heard that says the new Rams rattle. The one I test drove was as quite as my Dads 2013 Caddy and it was an Outdoorsman.
As far as the Grand Cherokee goes, those things can be ordered with more skid plates then any pickup truck ever built. Front suspension skid plate, fuel tank skid plate shield, transfer case skid plate and underbody skid plate! Along with a much better four wheel drive system too. So unless your running over pot holes at 35 MPH the GC is better protected then the trucks you list in your sig. But to each their own.Don
โSep-09-2014 06:58 PM
โSep-09-2014 10:30 AM
larry barnhart wrote:I am a Dodge fellow and I for one do not care who passes me or where. Never been in a race on the roads with anyone.
I find it interesting a dodge fella would be happy if another truck passes him so maybe the company doesn't feel the same as the torque will be more next year. However I feel the same as Don who cares but I am old. Happy is a good thing.
chevman
โSep-09-2014 08:05 AM
โSep-09-2014 07:11 AM
โSep-09-2014 03:24 AM
โSep-08-2014 05:42 AM
Well then the Eco-diesel I'm getting is not going to last very long then. We are looking a TT's with a GVWR 7800#. The first thing I'll do after getting it is order rims and new tires in the LT line.Don
โJul-05-2014 07:22 PM
NinerBikes wrote:
No one with a smart phone, the Torque Pro App and an ELM 327 OBD II bluetooth adapater uses idiot gauges any more. They get real, from the ECM, to the single digit degree numbers real time, digitally, not on an analogue gauge that the ECM dumbs down, because too many people freaked out and complained that the gauge actually moved upwards due to work being performed going up hill.
Torque Pro application for Android
If every one here was forced to ride a mountain bike up hill, up various grades, long grades, you'd think twice about putting your foot deep into the pedal going up hill and going fast, and you'd have much more appreciation for how hard you are working your motor, by doing so. Carry 3 liters of water on your back on a mountain bike, up hill, heck, how about a couple of 6 packs of beer even, and you'll gain an appreciation for work being done, by you, not by your engine and fossil fuel.
โJul-05-2014 07:07 PM
That fuel cap needs to completely seal off the fuel from external breathing or moisture ingress. Diesel fuel is highly hygroscopic. It absorbs moisture out of the air at an alarming rate if your tank has access to it due to daily cycle of high and low humidity in the air, due to adiabatic process of warm air holding more moisture, higher dew point, and cold air holding less moisture, lower dew point, and condensation inside the empty portion of this fuel tank.
โJul-05-2014 04:39 PM
boocoodinkydow wrote:Perrysburg Dodgeboy wrote:
Well then the Eco-diesel I'm getting is not going to last very long then. We are looking a TT's with a GVWR 7800#. The first thing I'll do after getting it is order rims and new tires in the LT line. Will I win any races going up hills, probably not but that's OK by me. All you guys that want to run 70+ can just fly by me.
Not sure what your talking about as to the Ram's fuel mileage. But it's no worse then the other brands. Better with the ED, show me any truck out there with an EPA rated 20/28 MPG. Go to Ramtrucks.com read the information and wait the videos on the different technologies Ram uses to improve fuel economy.
Don
My sentiments exactly ,don. Keep the rpm's in the sweet spot of the torque curve & let the speed & the gearing fall where they may. Still torn between a Fred motorhome & a tt of similar weight as your shopping list. I have no reservations that the ed is capable of towing it using moderately conservative driving habits.
โJul-05-2014 03:42 PM
Don
โJul-05-2014 02:44 PM
โJul-05-2014 08:33 AM
Sport45 wrote:NinerBikes wrote:
It's rather simple... see those gauges in your dash? See the red marks? Don't ever operate the vehicle in a manner that gets the gauges near or in the red marks. RED MEANS STOP DOING WHAT YOU ARE DOING to cause the needles to run near or in the red zone. Don't go there. It's that simple, not complicated. Running in the red has always come with caveats and warnings, in life. Nothing new here. It's just the dumbing down of America that is increasing.
Red means "don't go there", unless you want things to get expensive, complicated and broken on your piece of equipment.
Is that too hard a concept to grasp?
Good advice, but it doesn't work with many of the "idiot gauges" out there. For instance the water temperature gauge in my '00 Ford will show normal until it's too hot and then it will snap instantly to the red without letting you know you're getting close. The oil gauge in my '05 Envoy displays a computer generated pressure. As long as the pressure is over some threshold it indicates everything's normal. A fraction below the threshold it indicates zero.
โJul-05-2014 08:26 AM
Well the 5.0 Cummins will not make the fuel mileage that the 3.0 VM will and fuel mileage is what Fiat was going for. Would the baby Cummins make a better towing engine, yes but at the cost of fuel mileage.
Also VM is owned by Fiat so cost will be lower. It's smarter to in source then out source. Cost and quality can be controlled better not that Cummins has any quality issues. The 5.0 just did not fit the bill for what Fiat was trying to achieve. For Nissan and Toyota it makes perfect sense. They get the reputation that comes with Cummins and they can jump into the 2500 market. It's a win win for them.
Don
