โSep-03-2013 11:56 AM
โSep-27-2013 02:33 PM
โSep-26-2013 11:07 PM
CumminsDriver wrote:MTPockets1 wrote:ib516 wrote:
2013 F450 (4 door cab, diesel, 4x4, 8' box):
- max payload capacity of 4,969 pounds (diesel)
- max conventional towing 18,500 pounds
- max 5th wheel towing 24,700 pounds
- 14,000 pounds GVWR
- max GCWR 33,000 pounds (4.30 axle)
2013 RAM 3500 (crew cab, diesel, 4x4, 8' box)
- max payload capacity 5,800 pounds
- max conventional towing 17,000 pounds
- max 5th wheel towing 29,130 pounds
- max GCWR 37,500 pounds (4.10 axle)
Max Payload for the F450 Crew Cab 172.4" Wheel base is 7080 lbs.... per www.ford.com/trucks/superduty/specifications/towing/
5680 lbs max payload for the 3500 Ram ...... Other specs look right
There's no way the F450 pickup has a 7080lb payload. 14,000 GVWR - 7080lb payload = empty truck weight of 6920lbs. No way that truck is that light. More like 8500lbs or more empty.
โSep-25-2013 03:17 PM
Perrysburg Dodgeboy wrote:
And when did he start the rag?
Why is it when I post something from All-Par I get told they work for Chrysler. Yes they do, but they are not doing side-by-side comparisons.
Answer my question, why is it when the Ram was at the bottom of the HP/TQ along with towing and payload they ran a Ram 3500 and not a 4500 or 5500? Wouldn't that have been fair?
โSep-25-2013 02:37 PM
itguy08 wrote:Perrysburg Dodgeboy wrote:
Or maybe the 3500 Ram beat the F-450 so bad that Mike was told by Ford not to post it!? :B
If only he still worked there.... Been gone since 2011.
Mike's farewell.
โSep-25-2013 11:28 AM
โSep-25-2013 11:13 AM
โSep-25-2013 10:43 AM
45Ricochet wrote:They are probably waiting for Ford to announce the new 6.7 at the texas show tomorrow with 500 rwhp 1100 lbs torque, compound sequential turbos, titanium rods and integrated jacobs engine braking system;)Aridon wrote:
Looking forward to the results
Hopefully by Christmas :E Don't know why they are so slow in reporting the results. Maybe the Ford is still climbing the hill :B
โSep-25-2013 09:05 AM
โSep-24-2013 08:28 PM
โSep-24-2013 03:47 PM
โSep-24-2013 11:23 AM
โSep-22-2013 07:29 PM
โSep-22-2013 01:16 PM
โSep-11-2013 11:03 AM
BigToe wrote:
The following quote caught my eye:The Mad Norsky wrote:
"One thing you must realize is that the Ford works best when starting down at a speed in the 50 to 55 MPH range max. Starting downhill at speeds greater than that just means you will need to use your brakes."
I don't think the Ford is unique from any of the competition on this count. All vehicles work best when starting down hill in a lower speed. Physics dictates that the Ford is no different than a Volkswagon in that regard.
Starting down a hill slow and in low gear helps save the brakes regardless of vehicle brand or transmission type... whether with stick shift or with fancy electronic shift strategies.
