Ram Cummins locking fuel cap
Learjet
finally found a locking fuel cap for the Ram Cummins.
http://bem-auto.com/blog/dust-on-the-ezloc/
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
13 REPLIES 13
blofgren
LIKE2BUILD wrote:
I got my billet aluminum cap with o-ring gasket from amazon for $15. I didn't like the idea of dust or moisture getting in my tank. I figured $15 was really cheap insurance to avoid a contaminated tank.
KJ
x2. I bought this one recently because my truck didn't come with the plastic one from the factory. This one works great and I love how it sticks to the hinge while filling.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Learjet
Nikolaite wrote:
Cummins12V98 wrote:
The door has a soft rubber seal that does a good job of sealing the dust out. I'm thinking their test was done with the door open. I do think it's a good idea for sure. I use the Mopar cap that comes on the EcoDiesel trucks.
Hi, I'm Nicole from the Youtube video: https://www.youtube.com/watch?v=DZUUWSVDrTI
The video was shot after I drove out to my farm and back, approximately 62 miles. The fuel door was closed the entire time I was driving. When you're going down dirt and gravel roads the rubber seal on the fuel door does not keep the dust out. The EZ-Loc does.
I've run with my EZ-Loc since April and even installed a DEF-Loc when those came out. Since then, my green plastic diesel filler neck is nice and clean inside.
Plus...I don't think the filler neck compartment is sealed complete against the inside of the fender...like it should be.
B&W Ram Companion
Nikolaite
IdaD
KJ
Just added that to my Amazon cart - the little plastic plug I've been using lacks a magnet and tends to blow away on windy days. Worth $15 to fix that with a more permanent solution - thanks.
2015 Cummins Ram 4wd CC/SB
LIKE2BUILD
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
larry_barnhart
Cummins12V98 wrote:
I am not at all concerned with fuel loss. It's fuel contamination and injection system damage.
me also chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry_barnhart
We had a moron in our area that used a cordless drill . he decided the dodge truck was waiting for him to be a crook. He drove himself to the hospital with very serious burns. Something came out very good on this story. A jail bird with pain.
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
ChuckV1
I have always been a fan of a non locking fuel cap, if they want my fuel fine, I have had two friends that had locking fuel caps, one lost a full tank of full because the stuck a screw driver thought the bottom of the tank, the other only lost a 1/4 tank of fuel do to a Ice pick in the bottom of the tank ...
I figure a $40 or $50 loose is better than a $300 or $400 fuel tank ๐Ÿ™‚
Safe Travels
larry_barnhart
have a 2018 chev equinox and a no cap fuel inlet. Do I like that? No way.
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
Cummins12V98
IdaD
I'm not so worried about a cap that locks so I've still got the plastic factory plug stuck in mine. When it wears out I'll figure out another cap but at two years it still works fine. I'm on dirt roads a lot so I'm not really a fan of the capless setup.
RideSlow
Got mine from Geno's Garage.
2007 Dodge Ram QC 4x4 6.7 CTD 3500 SRW
2014 Stealth AK2612 TH
2004 HD Ultra Classic
