Ram Cummins T05 Recall
SweetLou
I know it's been written but what are your outcomes after the replacement part?
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
13 REPLIES 13
SweetLou
I had the recall done yesterday at the dealer. Seems that it is a cat and amonia sensor that got replaced. So far drives like normal. I hope the mileage doesn't suffer anymore than it already does.
We love our Westie
Cummins12V98
REPEAT, they will ONLY replace the WP if it does NOT have vent/weep holes. They DO have to inspect every vehicle on the recall list.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
centerline
ScottG wrote:
Sorry - off topic..
Did the defective pumps include service replacements? I replaced my WP back in 14 I think. I used a pump from Cummins - could I have a bad one?
very unlikely cummins would have sold you one of the faulty ones... its the same pump they have been using for a long time on their industrial engines... not sure how Dodge came to get a batch of faulty ones.
if you have replaced it on your dime, you can submit the reciept for the pump and cost of repair to chrysler for reimbursment...
when mine failed, it threw the belt, which wrapped around the fan and took out the wiring and fan control.... it was all replaced under "incidentals" due to a recall that was too slow in coming. because they didnt release the authorization for their dealers to do the recall until november 1st of 2017, and then it took a while for them to get the new waterpumps in to do the upgrade..
my waterpump failed the 2nd week in october of '17.. 2 weeks before the recall could have been done.
I purchased my replacement from cummins... it was correct.
My dealership said that when I get the recall notice, I should bring it in, as they STILL need to replace it under the recall to insure that it has been done correctly and with the right waterpump.. and I will get to keep the one they remove...
2007 M-3705 SLC weekend warrior, 5th wheel
2014 Ram 3500 CC/LB, 6.7 Cummins
2004 Polaris Sportsman 700
2005 Polaris Sportsman 500 HO
1979 Bayliner 2556 FB Convertible Cruiser
Heavy Equipment Repair & Specialty Welding...
Wild_Card
ScottG wrote:
Sorry - off topic..
Yes you can get reimbursed if you have your paperwork
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
ScottG
Sorry - off topic..
Cummins12V98
Did you look at the pump? Was it missing vent/weep holes? From what I have read the ones they WILL be replacing do NOT have the holes as they are the ones causing the problems. Ones with holes don't get replaced.
That sucks to get stranded!!!
Ron3rd
There is a recall on the water pumps for the later Cummins. Got my recall notice a while back. No parts yet for the fix
Equilizer Hitch
Honda EU2000
IdaD
Cummins12V98 wrote:
IdaD wrote:
I haven't had any issues with mine, but I didn't have any issues before it was done either.
I am wanting them to get the **** water pumps available so I can get that swapped. I got stuck on the side of the freeway once already and don't want to repeat that experience.
Your pump went bad on your current 15?
Yep, in Bumble*uck, Oregon on a 100 degree day towing the camper home from a vacation last summer with the family. I only had about 30,000 miles on the truck at the time. It was not a good day.
2015 Cummins Ram 4wd CC/SB
spoon059
Is this the one where they simply remove the ammonia sensor in the exhaust? If so, I think mine was already taken care of. Didn't have any problems before or after.
2015 Ram CTD
2015 Jayco 29QBS
Cummins12V98
Cummins12V98
It extends to the 3500's also.
IdaD
ScottG
Probably nice if members know what it's about:
"The EPA and California Air Resources Board have demanded a recall of 2013-2015 model year Ram 2500 pickup trucks with 6.7L Cummins diesel engines because moisture can lead to the deactivation of the selective catalyst reduction system, causing excess nitrogen oxide emissions, Cummins said.Nov 14, 2016"
