Oct-29-2016 12:12 PM
Nov-02-2016 10:39 AM
Nov-01-2016 06:48 PM
Grit dog wrote:
Weird, Ram is putting c rap oil in the trucks.
Here I thought I was just being all OCD by changing out factory fluids quickly on new or newer vehicles. Guess it's the right thing to do...
Nov-01-2016 08:47 AM
Nov-01-2016 06:19 AM
Oct-31-2016 07:06 PM
Oct-31-2016 02:43 PM
minnow wrote:Cummins12V98 wrote:
I have a MagHytec I took off my 11 Dually from what I have been told it will not fit the RAM with real air ride. I had no issue removing the bolts and letting mine drain thoroughly and wiping out the inside and bolting the cover back on and re filling. I do like the fill plug has a gasket as does the cover, both re usable. I like to see the condition of the gears especially on the first change.
Just flushed my '16, 3500 with air suspension this past week. There are two threaded rods that replace two pan cover bolts. These two rods are used to secure the air line tubing distribution valve to the diff. cover. You have to remove two nuts from the threaded rod and then remove the threaded rod from the diff. cover. I believe you could just reuse those threaded rods on the new cover however.
I had only 12500 miles on the truck but the rear was chattering somewhat when making turns. After replacing the diff. fluid that seemed to cure the chattering.
Oct-31-2016 12:39 PM
IdaD wrote:
I just changed out the rear diff fluid on my Ram at 20k miles. Why on earth did Ram not put a drain plug on the rear diff cover?
Oct-31-2016 07:21 AM
Oct-31-2016 06:26 AM
Oct-31-2016 04:57 AM
Oct-30-2016 05:43 PM
Oct-30-2016 04:32 PM
IdaD wrote:Bedlam wrote:
Don't the GM and Ram use the same AAM axle?
Yep, the 11.5". Different diff covers though. I think the LSD setup is different too or at least I recall seeing somewhere that some GM guys would swap in the Ram setup.
Oct-30-2016 03:08 PM
Oct-30-2016 02:54 PM
