Removing Contact Overloads
silverbullet555
Well, I am working on installing the 3500lb helper springs and was thrilled thinking they would be bolt on and go. Turns out, that might not be the case. In the directions, they say to you have to remove the contact overloads if your truck has them. I didn't think mine did because I was looking for something like the hellwig. I assume, the fat spring at the bottom is the contact overload.
Anyone have experience and tips for removing the contact overload spring from the spring pack?
When I remove it, how much am I giving up compared to the 3500 lbs I am gaining in spring?
Wondering if either bags or something else might have been a better option to maintain ride and minimize extra work. Probably all comes out the same.
Lastly, if I put the swaybar on before I take the overload off, is it going to make that process harder?
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
10 REPLIES 10
silverbullet555
Hellwig is sending me the right hardware. It appears the install kit may have been opened and returned at some point and thus the hardware issue.
Kudos to them for making it right, second day air.
Torklift mounts
Torklift superhitch
towpro
I would say the spring on top of this pictures is the contact overload.
as the body drops, that top spring comes in contact with mounts that stick out from the frame. this is a picture of Torklift upper (and lower) stableloads.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
narcodog
I have used SuperSprings from the get go, I have never touched them since I installed them and that was 14 years ago. Just sayin
silverbullet555
They are on my list for a call first thing tomorrow. I am not too impressed with their hardware kits so far. My 12 year old was the first to point out that it wouldn't work. And suggested longer u-bolts which is my preference.
Sounds also like it may be better to wait for the sway bar until the springs are done.
Torklift mounts
Torklift superhitch
AnEv942
I've always considered the bottom leaf as part of the main pack. Assumed describing a top contact overload like Ford/Dodge uses. Even IF bottom leaf was removed (I wouldn't) doesn't look like enough room to run back up bar and double nut U bolts?
Phone call to verify what they expect and off chance they mis supplied incorrect U bolts. Just looking at kits appears 3 sizes of u-bolts?
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
jimh406
I find sway bars to be always in the way, so I’d say do it last.
Assuming this is a commercial product, you should check etrailer for a video or youtube.
MitchF150
You need longer U bolts for the Hellwig overload spring pack is all... I would NOT remove that lower leaf..
I would call Hellwig customer service:
1-800-HELLWIG (435-5944), Local 559-734-7451, Fax 559-734-7460
Hellwig Products Co., Inc.
16237 Avenue 296 | Visalia, CA 93292
customerservice@hellwigproducts.com | techsupport@hellwigproducts.com
I had an issue with my set of Hellwig overload springs (they had 2.5" wide U bolts and I needed 3" wide U bolts... They shipped for FREE the correct 3" wide U bolts to me.
Good luck! Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
Oregun
Wonder what it would hurt to just get longer U-bolts.
cewillis
I don't know what they mean be 'contact overloads', either. But I do know that I did something similar on a similar truck, and certainly did not remove the bottom overload spring. In fact, I increased it's usefulness.
Top overload springs
My objective was to have the fully loaded truck ride at stock height -- which it did.
Cal
Grit_dog
Navigator
Navigator
Don’t remove anything. Presuming that’s the pic of your truck.
Bolt those suckers down and go! You’re good
If you had upper overload springs they would have to go to make room for the add a leafs
