replace front slider window
tuna_fisher
Just returned from a 1mo. trip to the NW.We hit a bump and a Pyrex dish jumped out of the overhead cabinet and went thru my front slider.I don't need a slide window and just want to replace it with a 1 peice.Can someone tell me the process and where I might find one.Would install plexie glass as I don't even look thru it, it's just there.It's a 95 Lance Squire lite, 8'6". Is there a site with step thru step instructions? Pictures really help. Oh, and a great trip otherwise. Was 61 just about everyday on the coast and we've come home to 109. Was 117 while we were gone,sorry we missed that,lol.
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
17 REPLIES 17
deltabravo
Info for others that might want to replace a window, or upgrade them:
My front slider leaked all the time when driving in heavy rain (water forces it's way in around the sliding portion.)
I ended up replacing that window and a few others with new, double pane windows from www.motionwindows.com/
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
tuna_fisher
Tried last night but the paper on the butyl tape was not wanting to pull off due to the heat. Brought it inside with the AC and let it cool overnight.This AM it pulled right off,popped the window in,screwed it and DONE!!! Lesson learned,cool tape better than hot to remove paper.Now setting it might be better when the butyl is warm so it spreads better.Yes, I'm a early riser,gotta be if you want to get anything done when it's 110 outside. Then you take a seista after lunch!!!
tuna_fisher
bedrocker wrote:
Tinted or non-tinted?
non tinted, now I don't have the slider center bar in my rear view mirror.
bedrocker
tuna_fisher
Got a peice of 1/4 plexi and replaced the center window where the 2 sliders were, got a roll of butyl tape for re-install,now when it's cooler than the present 108 I'll put it back in. Thanks to all for your suggestions.
tuna_fisher
Mello Mike wrote:
tuna fisher wrote:
Lance contacted me,they want $277 for a complete new window. Think I'll take her out and go to the glass shop!
Wow, at that price it must be a special window. 🙂
And I thought I was special, shoots that theroy all to hell
Mello_Mike
2016 Northstar Laredo SC/240w Solar/2-6v Lifeline AGMs/Dometic CR110 DC Compressor Fridge
2013 Ram 3500 4x4/6.7L Cummins TD/3.42/Buckstop Bumper with Warn 16.5ti Winch/Big Wig Rear Sway Bar/Talons w/SS Fastguns
My Rig
1998 Jeep Wrangler
US Navy Ret.
tuna_fisher
tuna_fisher
Have wrote Lance and just waiting for a answer.
countrykids
I replaced ours with the non-slider a few years ago. I called Northstar and they sent out a fixed front window. It came complete with framing with a screw pattern same as the original. I don't remember cost but think around $50. Anyway, just remove existing screws, pry window loose, scrape old caulk off, put on new caulk and screw in new window. I would think Lance could do the same thing.
2004 Born Free class c
whizbang
+1 on the local glass shop. The one here fixes glass cheaper than I can myself.
Whizbang
2002 Winnebago Minnie
http://www.raincityhome.com/RAWH/index.htm
d3500ram
tuna fisher wrote:
...So your saying I can just take out the whole frame and have a solid peice cut to fit? ...
Doing as you state was my first thought... you will have to asses the exact situation.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
tuna_fisher
It was the non slide side. So your saying I can just take out the whole frame and have a solid peice cut to fit? The vertical bars just pop out or do I need to buy a whole window frame and glass if I want a non slide? Thanks guys for your input.
d3500ram
Ditto to what Jim said, but I will add this:
...perhaps make a template yourself out of chipboard or similar (including any radius corners) to insure it fits and use it for the dimension take-off instead of just taking a tape measure and giving those to the glass cutter. I did this method for on of my overhead windows on a past camper and it was perfect fit.
