Jul-02-2019 02:42 PM
Jul-05-2019 04:35 PM
Jul-05-2019 04:19 PM
Jul-05-2019 03:16 PM
Grit dog wrote:
5 tire rotation doesn't get you any more miles per tire or miles per dollar unless you're literally banking on the value of that cheap factory spare tire. It does do a good job of complicating tire rotations though.
The one upside is if you have a 1 wheel peel vehicle and can't keep from wearing the right rear tire more than the other rear tire. Then a 5 tire technically makes a bit more sense and cents.
Jul-05-2019 11:00 AM
Jul-05-2019 06:41 AM
ktmrfs wrote:mapguy wrote:captbru wrote:
I rotate the tires at every oil change since new, I have the dealer due the oil changes right around 5000 miles.
I run the rear tires at 80PSI and the front at 75PSI.
Have about 5000 towing miles with the fifth wheel and then a few hundred miles with a utility trailer.
No lead foot while towing the fifth wheel on the Interstate I set the cruise at 62 or 63, never over 65 except to pass if needed. Then back to the set speed. On back roads I due the posted speed limit. When not towing I due the speed limit or no more than 75 on the Interstate if the posted limit is 70.
Hope this answers your questions. I'm just looking for a good set of tires, not what did you due wrong to cause the tires to wear down.
Thank you to the ones that answered, looks like Michelin is the way to go.
At those inflation levels running empty is like using 24 grit sandpaper on the tires. You will see excessive center wear on all 4 tires.
Are you running tires that match the door frame sticker on the truck? if so run the fronts at the inflation level indicated on the sticker. There is no need to go above the door frame sticker on the front tires as you cannot load them enough to need anywhere near max inflation.
If you truly want to get maximum mileage out of your tires -inflation must be set to match actual load. This means when running empty the rear inflation levels must be dropped to a lower level.
As far as excessive wear with high inflation and low load, That pretty much went away with the advent of radial ply tires.
I always have run both our trucks near max and never had excessive center wear, very even wear. And between them that's almost 300K miles. On my cars I run at high end of recomended inflation, mostly because of my driving style and again never had excessive center tread wear. And I'm running my trailer tires LRE at 80psi, when load inflation says 60 is enough and no center wear.
Jul-04-2019 01:16 PM
parkmanaa wrote:
You won't be sorry for going with the Michelin Defender LTX tires. Have used Michelin for more years than I care to remember, on cars, trucks, motorhomes and have NEVER had one failure. It's the only brand I buy, and insist my family does the same.
Funny how so many people blame the tire when they have a blowout. That poor tire may have been encountering everything the highway can throw at it for many, many thousands of miles, but if it should blow out, albiet years later, it's the manufacturer's fault. Never that piece of steel or 4x4 you hit many miles back, that weakened the tire. Always the manufacturer.
Jul-04-2019 08:00 AM
Jul-04-2019 07:56 AM
Charlie D. wrote:captbru wrote:
They checked for any warranty from Firestone, because there original tires nothing.
That's not what the manual I posted earlier said. I have found tire dealers in general do not like to prorate tires. I have even been asked "did you buy them here?" The manual I referenced has the phone number for the manufacturers. That sometimes doesn't help. BFGoodrich told me to take to a different dealer and gave me the name of who to contact. When I went to their place of business and said i was referred to them by BFG the owner said " You have got to be kidding me. I don;t handle their brand of tires."
Jul-03-2019 02:09 PM
Jul-03-2019 11:46 AM
Jul-03-2019 09:16 AM
Jul-03-2019 08:39 AM
Jul-03-2019 08:18 AM
downtheroad wrote:
Michelin®
Defender LTX M/S
Shop around for price....I went with Costco.
Jul-03-2019 07:55 AM
