Rieco Titan swingout jack-need a picture
T3PAIR
Would anyone be able to post a picture of their Rieco Titan swing out bracket? I'd like to install them myself but Rieco website lists two different models. The Swingout bracket and then the EZ Swing Bracket. Just seeing how this would install on my AF811 which has stationary brackets. Site says it bolts to the existing corner brackets. Anyone done this conversion before?
2016 Ford F350 DRW 6.7 Diesel, Firestone Airbags, On-Board Air compressor
2014 Arctic Fox 811, Torklift Tie-downs, Torklift fast guns
12 REPLIES 12
17oaks
You will need to take the swing out bolt out from time to time (annually for me) and clean and lube. I use a BRASS wire wheel to clean and polish up. Then coat with garage door lube (seems to work well) reassemble, total time for both, remove, clean, lube, install about 30 min, no tools needed, can remove by hand and install by hand.
Don
Texas
US Army (RET)
'15 F350 4x4, CC, LWB, DRW, King Ranch
2008 Arctic Fox 1150 TC
Vietnam Combat Veteran
John_in_PA
I have a pair of Reico-Titan EZ-Swing brackets in like-new condition I can sell at a bargain price, all stainless fasteners included. They were take-offs from my new camper a couple years ago, no longer needed.
jwellsgnr@gmail.com if you're interested.
John Wells in Hollidaysburg, PA
2012 Chalet Ascent S100F on a 2011 Chevy Silverado Duramax Dually
Bedlam
Moderator
Moderator
Bedlam
Moderator
Moderator
My AF811 started on a SRW and now sits on a DRW flatbed. Once I knew I was upgrading trucks, I bought and installed these brackets. With the jacks swung forward on my flatbed, I only have 1/2" clearance on either side (you can see the jacks could be fully swung in with the SRW). Although you might be able to "thread a needle" without brackets on a DRW, the chance for damage is too great.
The AF811 comes in a short bed or long bed model. My short bed model sits about 7.5' on my flat bed but is limited to about 7' if you have bed rails and tail lights. My AF811 has every heavy option and comes in about 4000 lbs when wet and loaded. It is within stock RAWR of most 1t trucks but works on 3/4t with some upgrades. We plan to go to larger TC in a couple of years which was the reason our DRW vehicle upgrade.
T3PAIR
Bedlam wrote:
Looks like you had the swing-out brackets when you still had your SRW truck. Any particular reason for that? Dirtpig, who replied one above you, mentioned that he has them as well on a SRW. On the flip side, can you get a DRW to fit without the swing-out brackets? I'm still toying with the idea of getting a DRW to fit with my AF811S.
Bedlam
Moderator
Moderator
Dirtpig
My 811 brackets look exactly the same as yukoners if that helps.
2015 Nash 25C bumper pull /w 300watts solar my install
My Truck & RV youtube channel
2005 F-350 Diesel 4x4 CC SB SRW
2001 Honda XR400: many mods
12ft Lund WC boat & 9.9 Yamaha 4 stroke on custom loader.
Yukoners
No worries! I get lots of help and info from this site as well:)
2006 GMC 3500 4x4 Duramax/Allison SRW LB CC Helwig Sway Bars, Bilstein Shocks, Firestone airbags, Rickson 19.5", Bridgestone M729F 225s, Airraid CAI, Lightforce driving lights.
2012 Arctic Fox 990 Torklift tie downs, Fast guns, Foxlanding, 2500 Onan gennie
T3PAIR
Thanks a ton for taking the time to post those pictures. I can see where the hinge would attach to the corner bracket now. Thanks!
Yukoners
These are on our AF 990 hope this helps if you need more give me a pm.
T3PAIR
Thanks. Anything will help. Just wondering if I keep the original corner bracket, attach the swing bracket to it, then the jack. Just haven't seen one before. Thanks again.
Boatycall
I did a complete Reico swap out and did a write up on it, I'll see if I can get the pics of specifically the swing outs.
Complete retrofit - swapping HappiJacs for Reico Titans-PICS
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
