โJul-03-2013 07:56 AM
โJul-10-2013 06:48 AM
โJul-04-2013 06:19 PM
Bud
USAF Retired
Pace Arrow
โJul-04-2013 02:51 PM
โJul-04-2013 02:10 PM
enblethen wrote:
Did you find the trailer connector fuses?
There should be two for each function.
Did you locate any relays in the fuse box for the trailer connector functions? If you have try swapping them with the trailer tailight one. It could have ate the relays.
โJul-04-2013 08:23 AM
Bud
USAF Retired
Pace Arrow
โJul-04-2013 06:31 AM
Dr Quick wrote:
Try this with your trailer battery connected. When you look at the connector from the trailer and the "index" it up, the 11 o'clock position is the hot or 12 volt to your trailer battery. Use a small jumper wire from 11 to 1 and the running lights will come on and also the tail lights. Go to the 9 or 3 position and the brake/turn lights should come on one at a time. It lights come on, the problem is in the truck, if not, the problem is in the trailer wiring. If tail lights or turn/stop lights do not work, it could be a bad ground to the rear lights.
โJul-03-2013 02:24 PM
โJul-03-2013 01:41 PM
Bud
USAF Retired
Pace Arrow
โJul-03-2013 01:31 PM
โJul-03-2013 12:46 PM
โJul-03-2013 12:33 PM
Hornnumb2 wrote:
If the vehicle lights are working correctly then it has to be in the truck plug, some of the factory ones just plug into a harness by the spare tire. Lay under there and follow the wire. Might just need to be unplugged to make good contact.
โJul-03-2013 11:43 AM
โJul-03-2013 10:19 AM
โJul-03-2013 09:31 AM
Bud
USAF Retired
Pace Arrow
