Safty chains
walterj628
We Currently have a 2015 22ft Premier trailer. I pull with a 2015 Duramax High Country.
The hooks on the safety chains do not fit the locations on the hitch. The angle / diameter of the holes prevents the chain hooks from fitting.
I've had to purchase 2 12" wire straps with D-rings to connect the chains to the hitch.
Does anyone else have this issue? Is this a design change for 2015. I didnt have this issue with my 2011 Silverado.
Thanks
27 REPLIES 27
trail-explorer
dodge guy wrote:
Its best to buy the proper tow vehicle that he safety chains fit in!
I can't think of a more proper tow vehicle than a full size truck, even for a somewhat small TT like the OP has.
Bob
Hannibal
I have to hook mine in from the sides of the receiver eyes. The hooks almost don't fit.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
hohenwald48
Huh???? What does that even mean?
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
westend
3/4" shackle:
'03 F-250 4x4 CC
ZeeLet50
I have the same issue. When from a 1500 to a 2500 and the loop for the chain to hook up to is different. Put the trailer away for winter so will address in the spring. Tried the closable links but they are not big enough to span the holes in the TV hitch. May have to buy larger hooks from TSC to resolve.....
2017 Grand Design Reflection 303RLS towed by a 2016 GMC 2500HD gas with Andersen hitch and B&W turnover ball mount.
LarryJM
Since each safety chain is supposed to have a breaking strength equal or greater than the GVWR of the trailer, I would recommend whatever you add have a "working spec" of at least 1/2 of that number or even better equal to the GVWR of the trailer. That was the "weak link" of this system is what the OEM chains were.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
harley4275
Thanks
Just grind off about 1/8" or a shade more off the tip part of the chain hooks that you push in with your thumb to get them off. Mine would not fit either till I did that ...Real easy fix.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
rbpru
I had the same issues with my 2011 F-150. The dealer installed one of those large links through each of the hitch chain connection holes.
They work just fine.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Jebby14
Sorry about the Chevy problem. Best burn it to the ground and buy a Cummins. In al reality my jeep dosent fit the chains on my boat. D shackles fixed the issue.
Q: Whats brown and sticky???
A: A Stick....
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
1320Fastback
Saw a pic of a set of safety chains hooked to the hitch pin...
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
beemerphile1
Same with my 2016.
I put eye bolts in holes that are underneath the bracket.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
AmericalVette
I had the same issue with a work truck and utility trailer. I went to Lowe's and got (2) a 3/8" Heavy Duty Chain Link; 2,200 lb capacity each. Slipped it into the holes on the hitch frame and tightened. The trailer safety chain hooks snapped right in.
Times fun when you're having flies!
