Separate Grey and Black Water Drains!
Frankly
Just bought a new Gulfstream Ameri Lite 268BH Camper. We got a very abreviated walk-through/demo. Not that we needed much as this is our 4th camper, and we have owned several popups and motorhomes, also. However, I just discovered that the holding tanks in this thing are 15 feet apart and the drains are separate! I have never ever seen anything like it. Is this one of the new modern conveniences? I don't think I am going to like this feature. For those who have it - what are your thoughts on this set up?
Jerry
2016 Gulfstream Ameri Lite 268BH
2006 Ford Expedition
17 REPLIES 17
hohenwald48
According to the specs here, you have2 gray tanks and 1 black tank.
http://www.rvusa.com/rv-guide/2016-gulf-stream-ameri-lite-travel-trailer-floorplan-268bh-tr25798
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Frankly
It is actually a tub shower and it does dump into the same tank as the toilet. It will not backup, because the toilet is lower than the tub bottom and it should have a trap to eliminate odors.
Jerry
hohenwald48
I doubt the shower and toilet go into the same tank on a modern RV. If they did, allowing the tank to fill would force human sewage to back up into the shower floor.
I have two gray tanks and I installed permanent plumbing to join them together. A "Y" in the flex hose was too messy for me to have to deal with.
Frankly
sharker6 wrote:
Your shower and toilet wouldn't dump to the same tank. Only the toilet dumps to the black tank. I've had separate outlets too and the 'Y' fitting is the way to go.
Maybe not...I did not trace the shower drain. Shower sits aft of the toilet and right on top of the black tank. I will check.
Jerry
sharker6
2017 Keystone Cougar 29RES, 2008 F250 Diesel FX4
ChuckV1
We bought a New Kz G384RLT this month, it has two gray water tanks but Kz was smart enough to connect them on the trailer. But there are two pulls, one for the kitchen and one for the bathroom sink and shower .....:)
Frankly
The Trailer Manual really does not say, but it appears that the shower and toilet dump to the rear tank, and the forward tank receives the kitchen and bathroom sink. After hearing the suggestions I think a Y connector will help make this more bearable. Thanks for the suggestions.
Jerry
Bucky_Badger
There are times where the kitchen is too far from the bath to run the pipe so the add another tank.
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
subcamper
Two separate outlets are usually used when there is a frame cross-member between the two tanks which prevents plumbing the two tanks together.
Our Rockwood has a single outlet for the black and grey tanks, and another outlet further forward for the galley tank.
Steve
LadyRVer
I have a gallery drain at back of rig and grey and black dump valves near the front. Usually use a Y connector.
DutchmenSport
My Outback has 3 valves but 2 outlets that are about 6 feet apart too.
One is black and grey (shower/sink and toilet). The other is grey (kitchen galley).
When camping with full hook-up sites, I use a Y in my hoses. When dumping at the dump station, I dump black and back-flush from grey to my black, then dump again. Then switch hose to the galley outlet.
Solution to your problem is to use a Y when camping, and use a longer hose (like 20 footer) so you dump the black first. Unhook the hose and walk it to the grey second. This way you don't have to move the camper.
It would be no different than the way I currently do it, just a few feet farther. I use a 15 foot hose for dumping at the dump station.
korbe
We may start to see more of this with the units getting larger and plumbing fixtures located all over the place. Only have so much distance to slope the underbelly pipes.
ken56
I have a rear kitchen and the bath is in the middle of the unit, same set up with the 2 drains which are about 12 feet apart on mine. I never have a problem dumping them, I just dump the kitchen first and then the black and grey for the bath. I don't leave my hose hooked to the takeoff as I prefer to dump and then put things away again instead of leaving it lay on the ground.
We_Cant_Wait
In most cases where I've seen separate dump points it's because there is 3 tanks. One dump has the grey and primary black tank, and the other a secondary grey tank is this the possibility?
