Sewer pipe?
Wallace_9967
What type of pipe is used on the sewer drain of TC?
4 REPLIES 4
AnEv942
Other thread you mentioned black so its ABS. Available just about any hardware store, big box store etc. ((ABS dwv pipe sizes). T/C generaly 1 1/2" on the gray water lines, (though a few use less common 1 1/4"), and 3" on the black water. Typically SCH 40 used and what youll find in off the shelf 'sewer' ABS pipe & fittings.
Lowes I believe sells pipe in less than 10' lengths.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
dadwolf2
ABS on mine
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
69_Avion
The black ABS seems to be more common and durable.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
Gripnriprod
If it's black it's ABS if it's white it's PVC. The one's I've seen have been ABS.
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
