โNov-15-2020 06:43 PM
โNov-21-2020 02:15 PM
โNov-21-2020 08:31 AM
โNov-21-2020 04:39 AM
โNov-21-2020 03:40 AM
โNov-20-2020 07:23 AM
Longshore wrote:
Well I think I'm going to get one of the Wolf Creek 850s I looked at today.
My GVWR is 11,500. My tare was 7,940. GAWR rear is 7,050 front is 5,600. They have one with an oven, kind of a must when the DW is along, and it comes in at 2,300 lbs dry. Interior height is 6'6'. They want 33,000 so I know they will take less. You guys think I should start at 28,000 and see their reaction? This will be a straight purchase.
โNov-19-2020 05:20 PM
โNov-19-2020 03:46 PM
Longshore wrote:
There are, apparently from my research, many truck camper rigs that are overweight. I do not want to be one of them. I will weigh things like kitchen ware as I load them. I have a telescope that weighs 40lbs. After all is done, if I need to upgrade the tires I will do it.
โNov-19-2020 03:42 PM
โNov-19-2020 02:38 PM
JimK-NY wrote:
It seems that you are a first time TC buyer so I can warn you that weights get out of hand quickly. For example if you start with a Lance 850, Lance estimates the wet weight as 2835#. First that is the base unit and does not include options such as awnings. Almost all units are going to come with options that bump up the weight by several hundred pounds. Even tiedown brackets and a bed mat add a lot of weight. Next you need to consider the weight of heavy accessories. Unless you are going to have hook ups at almost all times, you will want to look at a generator, a second battery, and possibly solar panels. Maybe you want to consider a better foam mattress... they are also heavy. In any case the 2835# camper can easily grow to 3500#. Then there are all the other necessities: food, cooking and eating gear, a few tools, extra boots and clothing, bedding, laptop/camera gear, etc, etc. You may think I am exaggerating but count on 1000# for these items. My 2400# base weight camper jumped to 4400# and I have looked carefully and don't find much I can do to trim back on the weight. Sadly a short bed pickup greatly aggravates the weight issue.
โNov-19-2020 02:26 PM
โNov-18-2020 04:22 PM
โNov-18-2020 04:01 PM
JimK-NY wrote:
My long bed transfers several hundred pounds to the front axle. That helps considerably. Second a long bed allows selection of a longer camper. With a short bed all the weight is likely to be on the rear axle and if the center of gravity is not substantially in front of the rear axle, the rig is not going to handle well. Look what happens when a trailer is loaded with too much weight in the back. Keeping the weight forward is going to help with the ride.
โNov-18-2020 08:38 AM
โNov-18-2020 08:28 AM
