silverado 4X4 stickers
ceasare
Has anone tried to remove these stickers? I'm taking off all the badging and I really want to take these stickers off too. Any ideas?
6 REPLIES 6
jbadtoy
You can use a old credit card and a hair dryer and it will work perfect. Goo gone works great for the sticky residue left over. If you don't have a old card,fishing line works great to just make sure you use gloves.
07 Z71 1500 4x4 6.0
08 3500 Dually 4x4 just for work
05 2500 D MAX 4x4 8 inch lift 37 inch toyos tuned,4inch exhaust,intake and more.
26ft Carson Inbox loaded for the toys
28ft Caliber One Boat
18ft Carson Car trailer
woodrow
Grit dog wrote:
Or heat 'em up CAREFULLY with a heat gun or propane torch. Use a hair dryer if you're uncertain as it wont get hot enough to burn the paint like a heat gun or torch.
Then scrub the glue residue off with some lacquer thinner or acetone.
OR get a 3M eraser wheel and just erase them off the truck with your drill. WOrks pretty good, very little glue residue cleanup usually.
Torch?..No!..Scrubbing? No!!..Follow the above..heat gun or hair dryer to remove the decal (sometimes in pieces) Then use something like goof off and allow the adhesive to get gummy..gently rub with cloth or paper towel and changing out the towel or cloth as needed..let the petroleum do the work..wax after cleaning/rinsing..
2013 Arctic Fox 811
'07 Duramax Crew Cab/Thunderjet Luxor Offshore
Sold: Flagstaff TT/Forest river 23t/Cougar 314 5er/Arctic fox 811/2000 Tioga 29z class c
Grit_dog
Navigator
Navigator
GWolfe
I left mine out in the sun for a while to get it nice and warm and then picked/peeled them off. I used Goo-Gone to get off any sticky residue that remained.
2005 Sun-Lite Eagle
2011 Silverado
therink
I took mine off once with wife's hair dryer. It was only one year old so maybe they were still flexible. It was also a hot day which helped. Took about 5 minutes each.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
1oldtruck
Try a heat gun. Heat them lightly until they start to peel. It won't be fast but it does work.
