Sizing a power tongue jack
Jimbee
Hey All,
I'd like to replace the manual tongue jack with a power jack but not sure how much lift I need. I have a Passport 2910BH with a tongue weight in the 975lb to 1050lb range depending on how much water/stuff I'm carrying. Would a 3500lb capacity suffice? Some brands are quieter than others, how about the Husky 3500?
Many thanks!
7 REPLIES 7
Bigbird65
One thing that I ran into with my electric jack was that I was not able to put the tail gate down without it hitting the jack motor. To correct this problem I rotated the jack 120 degrees to the left. Since the mounting bolt holes are not exactly 120 degrees apart I mounted the jack with 2 bolts and marked the jack mounting plate from below. I removed the jack and drilled a hole in the plate, then reinstalled the jack. The whole job took less than 30 minutes but I'm slow.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
lanerd
I don't think the OP realizes that you can use the tongue jack to lift the back of the truck to attach WD bars....or else he'd know to get the biggest one.
This addition to my TT was probably the 2nd most important thing I purchased for it.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
fla-gypsy
Get a minimum 3500# jack and all will be well.
coolbreeze01
Bigbird65 wrote:
I bought this tongue jack about a year ago and really like it.
Mine looks just like that but is branded RAM. Quiet and effective. Has to be covered to keep rain out.
Didn't have to cover the Atwood on the old trailer.
2014 Sandsport 26FBSL
Dakota98
That's what I have also. 3650# capacity. LOVE IT !!!!
It lifts the back of my truck. Works great in setting up the WDH.
18" travel, If you need more travel, just add a 6 x 6 block of wood under it.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
Bigbird65
Dick_B
My 3500 lb jack raises the front of the camper and the back of the Suburban just fine.
Whatever you consider make sure it will fit in the existing hole and align with the bolt holes.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
