Soft or hard water to fill up the tank?
Kayteg1
I read some conflicting reports and always find tons of sale pitching about water processing.
So I have water softener in my house and it is great for showers, leave not much water marks and so on.
But on the other hand water softener are getting rid of calcium and nutritionist say we need calcium.
At home I am in the process to run separate tubing to fridge, with unprocessed water where build-in filter will remove chemicals, hopefully leaving calcium, but in TC we have 1 tank and we use the water for consumption.
So any specialist can say how important is calcium for our bodies? I would prefer to fill soft water, but also plan to live long and healthy.
16 REPLIES 16
Kayteg1
But than again, how much health benefits are you loosing by drinking sodium ions instead of calcium?
rr2254545
Old-Biscuit wrote:
We FTd for 7 yrs using a portable water softener...WHY?
Because MANY areas of the US have 'hard' water and the scale was showing up on faucets/showers/toilet bowl--seal and inside water heater.
Now if we had been campers I wouldn't have bothered.
But we were FT traveling weekly somewhere new.
The portable water softener used resin beads that would 'collect' the minerals (calcium, magnesium)....in doing so the sodium on the resin beads is released
When resin beads become saturated with minerals you do a 'regen' using regular table salt. Dump a box of salt in, let it set for 20-30 minutes then rinse for 15 minutes. Ready to go again.
I would typically get 7-10 days between regens.
Scale at faucets disappeared, shower walls/door cleaned up, toilet bowl/seal required less cleaning and water heater didn't acquire as much scaling/crud between flushes
Water tasted OK but was 'different'....didn't have same taste
Hook up was pressure regulator, in-line carbon filter then water softener,
Filled fresh water tank and ran off pump ONLY
We used the softened water for bathing, dishes, cooking, drinking but made our coffee and Ice tea with bottled water.
Ice tea just didn't taste right and the powered cream she used would NOT dissolve in the coffee ----just clumped up
If going to buy one....get whichever one is lowest sale price. They are all the same..same resin beads system, same table salt regen, some just larger capacity
8000, 10000, 16000 grains
RV Portable Softener Info
Great info - we got ours direct from the manufacture for $173 no freight or tax
Best purchase I have made for the RV
http://flowpur.com/html/rv-pro10000.html
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
Old-Biscuit
d3500ram
ions, schmions...
...fill the tank with water and go camping!
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
pianotuna
Nomad III
Nomad III
The calcium ions are replaced with sodium ions.
Regards, Don
2oldman
Now that I look at it again, I think you're right. No wonder soft water ate out my metal shower drain.
Kayteg1
2oldman wrote:
I would suggest doing a bit of research on soft water. Some misinformation here.
I did say "lot of sales pitch" didn't I ?:W
Per my research water softener replaces calcium in chemistry with sodium, what is not actuall salt.
When it makes water feel soft, softener is not removing the minerals, just change the way they are suspended in chemistry.
That shows how ignorant I am in chemistry and that is why I started the topic.
Sam_Spade
Wrong question.
You should be asking: How much calcium will I be getting from MY water source if I do not run it through a softener. The answer usually is: A minuscule amount.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
2oldman
pianotuna
Nomad III
Nomad III
Soft water replaces the "hard" elements with salt. Salt is not recommended.
Regards, Don
Second_Chance
As stated by others, "hard" water (water with iron, calcium or other minerals) will wreak havoc with your plumbing and fixtures over time. We filter all water that goes into our rig, although we haven't sprung for reverse-osmosis or softening systems ($$$).
If you're not getting enough of the basic minerals in your diet, you're NOT going to get them from water. A balanced diet and, in some cases, a good multi-vitamin are the best ways to do that.
Rob
Retired Army nurse
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
jimh406
I use my home water when I can. Otherwise, I use a water filter to fill up my tanks. I'm not sure how much it filters, but it's at least something.
I agree that if you are worried about calcium, take a pill or eat/drink foods with Calcium.
SideHillSoup
Hard water has minerals in it "most" of the time, and is "usually" found in ground / well water.
With time those minerals will clog up your metals pipes / fittings and start to eat any metal parts it comes in contact with.
Now this won't happpen over night, but it will slowly start to screw up the metal pipes and anything else the water comes in contact with, mostly metal.
However if a bunch of the scale breaks off from a metal pieces it can and will clog smaller water lines like you find in a fridge or water cooler.
Just ask any steam engineer what the water treatment plant is for in a steam plant? The main reason and main purpose is to soften / clean the water used in the boilers.
Little different application for your house or RV but that's what will happen in time if you don't soften your water.
We are lucky where we live we are on river water and do t have those issues, we have other issues that we deal with.
Soup.
2018 Northern Lite 8-11 EX Dry Bath
2017 Sierra SLE, 3500 HD / 4x4 / Duramax with a 6 speed Allison Trans
Torklift Super Hitch 20K, 48" Super Truss, front and rear frame mounted tie downs
Fast Gun Long Range SS Turnbuckles, Fast Gun locks
Gary3
Our well was 80 grains hard softener for household use and buy bottled water to drink and make coffee softened went in the camper.
Gary  Lance  1191 solar Gen.
