Sep-17-2018 06:00 AM
Sep-21-2018 08:59 AM
blofgren wrote:
Have you actually scaled your rig loaded? I'm not sure taking the % of the dry pin weight x the GVWR is all that accurate because the pin weight will vary depending on how the trailer is loaded.
Sep-20-2018 08:54 PM
Me Again wrote:
If you create a percentage for the dry pin weight divided by the dry weight of the trailer and then apply the percentage to the GVWR of the trailer, you will be close to the loaded pin weight.
Here are our numbers. Dry pin 2435, Dry weight 13050 = 18.66 percent
18.66 percent times the 16 GVWR = 2985 loaded pin weight.
This is why we choose the BH3575el to tow with our SRW 2015 RAM 3500 4x4 SB truck.
If this trailer was pin heavy from the factory at say 2900, then loaded pin weight would be around 3556 pounds and I would have been over my RGAWR. Chris
Sep-20-2018 08:12 AM
Sep-20-2018 07:36 AM
Sep-19-2018 08:47 PM
Sep-19-2018 07:59 PM
larry barnhart wrote:
A few winters ago I talked many times to the owner of a large Teton fifth and he towed with a 2003 GMC dually. He bought an early 06 duramax and I asked why not wait for the new engine and his jaw dropped. then I asked if it towed better than the older 3500 dually and yes. He then told me our 35 alpenlite was heavier than his 4 slide large Teton so what does it weigh I asked. Never weighed it so the above post I believe are true. Most don't know.
chevman
Sep-19-2018 06:09 PM
Sep-19-2018 05:16 PM
Sep-19-2018 02:30 PM
Sep-19-2018 12:43 PM
Sep-19-2018 12:41 PM
Mickeyfan0805 wrote:Walaby wrote:
I don't think it's the VAST MAJORITY.
There is always the 1 percenters. For those people, it doesn't matter. If they don't care about the numbers, they don't care about any numbers.
Mike
Walk through a campground someday and ask how many people have pulled their rigs onto scales, calculated the weight of their fluids, or itemized their load to estimate weight. I would be shocked if that number were as high as 25% (and I would bet it's lower than that). I'm not suggesting that the vast majority of people are overloading their trailers, but I am suggesting that most do not actually know how much weight they are putting into the rig.
I could be wrong, and I'd love to find out that I am. But from the people I know in camping, and the many conversations we see emerge here, I just don't see it.
Sep-19-2018 11:37 AM
Mike
Sep-19-2018 11:10 AM
Hannibal wrote:ShinerBock wrote:
The math still does not add up. What rear gear did each truck have and at what speed did you pull these hills to get these rpms?
2003 SO Cummins Ram 47rfe/4.10. 2010 5.4L F250 5spd TS/3.73. 60~mph.
Sep-19-2018 10:43 AM
I believe the reason many people recommend using GVWR to ensure one has adequate capacity with their TV, is it would represent the potential worse case weight of the trailer, when loaded.
I get the 'first glance' usage of GVWR for evaluating a trailer, but to me, the danger of this advice is that the GVWR of the trailer does NOT represent the worst case scenario. The GVWR of a trailer indicates how much load that trailer is able to carry - it has nothing to do with how much a person will actually put in! The vast majority of RV owners are going to load what they are going to load - with no consideration of weight.
The person who has 10,000 of free capacity to tow a trailer, who then buys a 9,000 pound 'dry' trailer is going to be the same weight, in the end, regardless of whether that trailer has a GVWR of 9,500 or 12,000. In this case, they may pull out at 10k, within the ratings of the truck, but OVER the ratings of the trailer if they buy the lower GVWR vehicle. This makes them significantly less safe than buying the rig that has a GVWR over their capacity.
I just think it points people in a false direction of thinking that GVWR on a trailer will somehow impact it's final weight. There are trailers out there with cargo capacities under 500 pounds. Those people may have a trailer with a GVWR that fits within their specs, but most of them have well exceeded that GVWR on the trailer anyway.
