SRW or DRW?
welsteach
Considering tc that weighs roughly 3800 dry. Would a 1 ton single rear axle be okay or do I need to look at double axle only. Please, no truck brand wars. Stick to axles. Thanks.
31 REPLIES 31
RamTC
You'll end up exceeding the tire/rim ratings, some choose the SRW but upgrade with aftermarket tire/rim combos that can handle the weight.
Present - 14' Ram 3500 4X4 DRW CTD AISIN 3.73
Past - 98' Ram 3500 4X4 DRW CTD / 99' LANCE 1110 / 04' ARCTIC FOX 990 / 05' ARCTIC FOX 990
donn0128
3800 dry is going to translate into a lot more than that loaded ready to travel. You may be beyond even dually terratory except the 30000 dodge
